Question about LG WD-1280FHD Front Load Washer
My LG WD1238C door won't release when the cycle has finished, unable work out how to get it open, rerun the cycle also with no result. Anyone have an answer?
SOURCE: can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
Posted on Nov 20, 2008
MNTECH
  • 1543 Answers
SOURCE: Oour Machine (WD1238C front Loader)
Try turning off the cold water valve, unscrewing the cold fill hose, remove inlet screen, clean screen, reassemble and turn water back on.
Posted on Nov 28, 2010
SOURCE: My washing machine LG
Had the same problem with a slightly different model. Had to remove and replace the water pump at the front of the machine. Phillips screwdriver and some pliers are all you need. The pump had leaked past the shaft seal where the impeller is and got gunked up. New pump was $48.00 NZ dollars inc gst.
Posted on Jan 12, 2011
  • 6277 Answers
SOURCE: LG FRONT LOAD WASHER MODEL.
(It COULD be that there is water still inside which is why the machine keeps the door locked. It therefore could be a problem with the drain filter or the drain motor. I'm having to guess!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 07, 2011
rickead1
  • 1998 Answers
SOURCE: LG WD1238C front loader water is leaking out of
The cause of this is almost always something blocking between the outlet of the dispenser housing
usually it is the large hose that goes from the dispenser to the top of the tub itself if you remove the 2-3 screws along the back of the machine and slide the top cover towards the rear of the machine and then remove the top cover completly this will give you access to this area Usually you will find a large soap deposit or debris stuck in this hose or near the outlet of the soap dispenser housing itself . You have to remove the top cover in order to physicly clean and check these areas if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Jun 21, 2011
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
LD WD1238C Door is Locked shut tried every trick you can think of including giving it a little kick
often on the upper grade washing machines, the components are a little more sophisticated. Possibly once you have removed the top lid, you will see the door latch from the back. some of the latches have a drawstring that you can pull which mechanically releases the door and opens. If you are able to before getting into stripping the wachine, gie it a quick cycle run and let it complete the cycle, Then try and open it. go from there.
May 19, 2010 | LG WD-1280FHD Front Load Washer
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
LG WD-1280FHD Front Load Washer Logo
81 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
