Question about Zebex Computers & Internet
Hi, I have an a-62m-G2 Zebex Scan Module with USB interface, I need the driver and communication protocol for Virtual-Com mode so I can develop a software for my specific application Best Regards, Arashk
honey2509
  • 146 Answers
SOURCE: Nvidia Quadro4 (128MB RAM) driver required for linux 2.4.20.18.7
hi there..
here is the link for your Quadro 4 Graphics for linux 32 Bit
To download and install the drivers, follow the steps below:
STEP 1: Review the NVIDIA Software License.
You will need to accept this license prior to downloading any files.
STEP 2: Download the Driver File
Download - NVIDIA-Linux-x86-96.43.05-pkg1.run
SuSE users: please read the SuSE NVIDIA Installer HOWTO before downloading the driver.
STEP 3: Install
Type "sh NVIDIA-Linux-x86-96.43.05-pkg1.run" to install the driver. NVIDIA now provides a utility to assist you with configuration of your X config file. Please see Chapter 3 of the README or run 'man nvidia-xconfig' for details on usage. Instructions for those wishing to edit their X config file by hand can also be found in the README.
__________________________________
here is the link for your Quadro 4 Graphics for linux 64 Bit
Download - NVIDIA-Linux-x86_64-1.0-9639-pkg2.run
STEP 3: Install
Type "sh NVIDIA-Linux-x86_64-1.0-9639-pkg2.run" to install the driver, then edit your X config file as appropriate. If you are using a Linux 2.6 based system, type "modprobe -q agpgart", first. See the text README for more detailed instructions.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 19, 2008
marked
  • 6487 Answers
SOURCE: wireless-G USB adapter doesn't work on W98-SE
If you're sure that you're typing the correct key on the correct place you can try setting a static ip, subnet , gateway and dns server on it.
Posted on May 09, 2008
SOURCE: Need PC Suit and Usb Drivers for Chang Jiang N958 Chine mobile.
driver 6227 VIDEO(IAD_if
Posted on Sep 13, 2008
  • 3 Answers
SOURCE: HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Posted on Jan 10, 2009
  • 56 Answers
SOURCE: I Have Samsung SVP-6000 Presentor and I need
go to www.driverguide.com
you should be able to get your drivers from there and its free to join.
Ian
Posted on Mar 13, 2009
I have a 1998 cadillac saville none of the windows will roll down checked all fuses under the back seat and under the hood all fine.
The power windows on your vehicle are controlled by a electronic module .
Each power window is connected to a permanent magnet motor. The motor raises or lowers the glass when the door module applies voltage to the motor. The direction the motor turns depends on the polarity of the supply voltage provided by the associated door module. All four doors have their own separate modules.
A serial digital communications link, called the simple bus interface, is used for communications between door modules and the driver's door power window switches. The use of serial digital communications allows the use of a single wire to convey switching information between the LH front power window switch and the driver's door module. The serial communication is also used to transmit switching information from the driver's door module to the other three door modules.
The door modules apply battery voltage of the correct polarity to the respective window motor when any local, or power door lock switch, UP switch is operated, driving the window up. Battery voltage is applied to the respective window motor in the opposite polarity when any local, or power window switch, DOWN switch is operated, driving the window down.
The first place to start when diagnosing a problem like ths would be to hook up a factory scan tool , checking DTC'S - diagnostic trouble codes. Without a factory scan tool ,forget it , you have no chance of fixing this . Take it to a cadillac dealer . Could have problem with the
Simple Bus Interface (SBI) Serial Data Link
The simple bus interface is a serial data link. This serial data link replaces vehicle cables between various door modules with a single wire. The same amount of information is sent by multiplexing (time-sharing) data to and from each device over that wire. The serial data signals are referenced to ground. If the simple bus interface is lost, the RFDM, LRDM, and RRDM will enter the sleep mode. With the door modules in sleep mode, no power window operations are possible.
002 Introduction to Communications
Jun 21, 2017 | Cadillac Cars & Trucks
Where is the Body Control Module located?
I'm just curious if your aware of the BCM function's on your vehicle an if you know what the gate way module is ? An do you know about serial data communication between modules ? An do you know what the power mode master is ? And do you know the BCM needs programming ?
The body control module (BCM) in this vehicle functions as a gateway or translator. The purpose of the gateway is to translate serial data messages between the GMLAN high speed buss and the GMLAN low speed buss for communication between the various modules. The gateway will interact with each network according to that network's transmission protocol.
One example of this necessary communication is the communication between the engine control module (ECM)/powertrain control module (PCM) which is high speed serial data and Theft Deterrent Module which is low speed serial data. If these modules can not exchange information, the vehicle will not start.
Communication between the BCM and a scan tool can be on the high speed GMLAN network or low speed GMLAN network. If one network is lost, the BCM can still communicate with the scan tool. A lost communication DTC typically is set in modules other than the module with a communication failure.
Mar 04, 2016 | 2007 GMC Yukon XL Denali
Teredo Tunneling Pseudo Interface cannot connect or start
If this message is in windows, then it is all driver problems. Try going to the intel website and looking up your motherboard, there should be several drivers in multiple categories to download, or one package, get the newest ones and install them all. Intel Driver Update Utility
Apr 14, 2014 | Intel Desktop Board D845GLVA...
Unable to load client protocol
b> Internet Protocol, also known as IP, is a communication protocol which heavily uses the TCP/IP standards for packet switch internetworking. IP manages addressing methods for data encapsulation and delivery. IP was developed by the United States Department of Defense and is now widely used by the public. IP Version 4 is the fourth version of Internet Protocol and the first one to be deployed to the public. Updating and installing Internet Protocols are important to the integrity and reliability of your Internet connections.
Click the "Start" button at the bottom of your desktop screen. Click on "All Programs." Select "Run" from the Accessories folder. Type "CMD" in the run dialog box. The command prompt window will appear. Type "Netsh Interface ipv4 install" on the command prompt line. Press "Enter." Restart your computer.
Add or remove a network protocol, service, or client
http://windows.microsoft.com/en-GB/windows7/Add-or-remove-a-network-protocol-service-or-client
Feb 06, 2013 | Microsoft Internet Explorer 8
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
Hi there i have an LGU970 Cell Phone and i have forgotten my security code and was wondering if there was any kind of defult code or something so i can fix the problem,thanks for ur time :)
Make sure you have downloaded latest QFG Module and also have LG drivers from support installed ... cool.png
1. Download U970 unlock file (in Lg3g Folder) and u970 NV file (in NVM Folder)
2. Hold 2+5+ON to put LG in download mode and connect to original SHINE USB cable (recommended to connect to PC USB slot NOT USB HUB to avoid errors) drivers will automatically install
3.Open QFG Module, SCAN FOR INTERFACE ... choose correct COM and choose job as FULL FLASH ... make sure FORCE MODE is ticked ... press DO JOB and locate u970.UNLOCK file ... press OK
4. Have a cuppa wink.png , it will take about 45min to FULL FLASH (FGOLD BOX will give warning message during FLASH, check phone is powered on - JUST LIGHT IS ON IT DOES NOT HAVE TO BE ON FULLY - and press OK if NOT follow instruction given on warning message and press OK)
5. After FLASH switch phone ON and RECONNECT to USB CABLE ... SCAN INTERFACE ... choose correct COM ... choose do job as NV WRITE ... make sure FORCE MODE is ticked ... press DO JOB and locate u970.NV file ... press OK
6. RECONNECT TO USB CABLE ... SCAN INTERFACE ... DIRECT UNLOCK ... OK
Enjoy your LG SHINE now it is UNLOCKED for any network and aslo has LG KU970 generic software in it no more of the 3G theme smile.png
http://www.gsmdoser.com/ is where you download the Flash Files
Apr 16, 2011 | LG Shine CU720 Cellular Phone
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface Dot11Radio0
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
authentication key-management wpa
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
Door module
no, different.
Principles of Operation
Note: Upon installation of a new driver door module (DDM), the module must be reconfigured. Refer to Section 418-01 . The DDM is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
The driver seat module (DSM) is connected on the standard corporate protocol (SCP) communication network. The DSM controls the driver power seat and communicates with the driver door module (DDM) to control the driver seat memory and both outside memory mirror functions.
The lighting control module (LCM) is a microprocessor based module that controls several vehicle subsystems. The LCM responds to electrical input signals from various switches, sensors, and external modules. The LCM is located under the LH side of the instrument panel. Subsystem functions of the LCM include headlamps with autolamps, turn signal lamps/hazard flasher lamps, cornering lamps, parking lamps, daytime running lamps (DRL), courtesy lamps, demand lamps, battery saver and control backlighting. The LCM interfaces with the driver door module (DDM) through the standard corporate protocol (SCP) communication network for the illuminated entry feature.
The air suspension module is linked to its own data link connector (DLC). The air suspension module controls the air suspension and the variable assist power steering VAPS. For additional air suspension system information, refer to Section 204-05 .
The air suspension module is used to monitor and control the VAPS system. The VAPS system controls the level of power assistance available to the driver based on vehicle speed and rate of change in steering position. For additional VAPS system information, refer to Section 211-00 .
DESCRIPTION AND OPERATION Module Controlled Functions
DIAGNOSIS AND TESTING Diagnostic Trouble Code Chart Air Suspension Module Principles of Operation
Inspection and Verification
Symptom Chart
Pinpoint Tests
Driver Door Module (DDM) Principles of Operation
Symptom Chart
Pinpoint Tests
Driver Seat Module (DSM) Principles of Operation
Symptom Chart
Pinpoint Tests
Lighting Control Module (LCM) Principles of Operation
Symptom Chart
Pinpoint Tests
REMOVAL AND INSTALLATION
Apr 24, 2009 | 2004 Lincoln Town Car
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
SCAN to pc useing Copystar 1820
please specify how the machine communicates with computer (network, USB cable, or parallel cable). once this is known I'll be able to tell you how to setup the scanning.
As for the 2nd question, yes this machine does support vista, both 32 and 64 bit
May 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Computers & Internet Logo
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
