Question about Sport & Outdoor - Others
Manual for dalps vibrate shape machine, model number is 9800ms
I need a manual and parts book for a treadle sewing machine. Serial number B481745. I believe model is 27.
go google and type in---workshop manual for singer sewing machine model 27--
the beauty of singer is that there were few changes made in the treadle series so any book around that age would be helpful
Sep 10, 2016 | Singer Sewing Machines
Need manual
Go to your search engine (I use Google Canary) and type in the information about your sewing machine and then type the word manual. For example: "Singer model number XXXXXX manual".
Mar 26, 2015 | Sewing Machines
M/N ETW4400SQ0 The small pin, 2" with cotter pin hole in the end, underneath the machine, with a opaque capture shield has come loose from the spring it holds? In turn during spin cycle the...
Hello Mike
Those cotter pins with the shield over them were part of the shipping braces from when it left the factory and they do have no bearing on the suspension system.
What most likely thats causing it to vibrate so badly are the cresent shaped plastic peices that fit between the plates under the outer tub,Their is 2 types of those on the washer one fits under the bottom plate and one fits on the top of the bottom plate andin between the upper and lower plate. They are impregnated with teflon and have worn out so instead of the plates sliding free the are grinding against each other
Those parts are called suspension pads,the part number for them is 285744 &285219 they can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
This link shows where they are they are item numbers 13&15
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Washer-Parts/Model-ETW4400SQ0/3191/0153200/W0607071/00005?blt=06&prst=0&shdMod=ETW4400SQ0
GENE
Sep 24, 2011 | Whirlpool Washing Machines
Machine not vibration at all. Can you give me a site which I can see a manual
If it is an HP machine, see: http://support.hp.com and enter the model-number, and do a search.
Mar 02, 2011 | Computers & Internet
Lost my manual for my poulan pro 255 chainsaw the model number seems to be missing on the machine. i have a balance spring underneath thats broken near the rear of the chainsaw. need a part number for the...
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Feb 14, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Nov 22, 2009 | Kenmore 24902 Top Load Washer
My machine was vibrating during spin. so I took
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The section on the Base should have a diagram of where the springs and vibration pads attach.
Ths following Whirlpool Service Manual for top load direct drive washers also has a section on the base and where the springs attach.
Nov 15, 2009 | Kenmore 24032\24036 Top Load Washer
Finding a manual or something to trll us about this machine
what model is this machine, someone could help you ....if we knew the model number.
May 12, 2008 | Gestetner Copier
Sport & Outdoor - Others Logo
230 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
