Question about Sony Ericsson P1i
My Sony P1i just went dead one day. it won't power up. Battery is fine. when u plug power the light glows and steady. repair shop says software needs reload, is there i can do myself, itried firmware update but no result. it says no firmware update required for this phone.
My P1i appears completly dead after running Update Service. I've tried removing the battery, fully charging the battery etc. When i run Update Service again it just says my phone is up-to-date.
any suggestions?
Update only says "No new software is available for your phone. Your phone already has the latest available software installed."
Then gives the option to Exit only
Posted on Feb 19, 2011
2000 vw new bettle diesel won't start battery dead when i bought it touched it w/starting fluid cranked cut off
If the engine does not reach 300 rpm while cranking..engine will not start.
It needs good battery power to crank these with spare power to run the electronics.
If with good battery if fires and immediately stops, and the little 'yellow car' is illuminated in the cluster.... the immobiliser is active and you need a shop to fix it.
BTW..Stop with the Easy Start fluid already. You'll break a piston ring or worse...such as....the Glow Plugs will cause a back fire and you will likely strip the timing belt...major repairs...like $3500 and up.
Sep 05, 2011 | 2000 Volkswagen Beetle
Gud pm?ihave problem my phone sony ericksson p1i, my p1i does not turning on instead, black out and when everytime turning on it was just vibrating for sec and shutting down. please i nid advise for this...
Double Check that battery is not the problem
when battery falls below 5% it starts off to blink in all SE Phones .. i think that was the case with your phone .. with such low battery u can’t power up pi on phone
Jul 11, 2010 | Sony Ericsson P1i
Dead P1i; wont power up; wont charge
the bios might need to be flashed. . have it flashed or reformatted by a technician
Feb 16, 2010 | Sony Ericsson P1i
Intermittent battery dead.
This is not an easy repair. The system has a short or draw on the battery that could be located anywhere. I would take to a good local mechanic. The time involved could be very high in excess of 4 hours just to find the problem.
So taking to a shop you can trust can save you a lot of time. I know auto zone does some basic test to check the charging system. The alternator and starting system to see if there is correct out put on the alternator and if there is a draw on the starter for free. I guess that would be a good place to start.
Good luck
Jul 16, 2009 | 2002 Nissan Pathfinder
Sony ericssion p1i screen touch problem (not working touch screen)
Try removing the battery and pushing power button to discharge capacitance.
Check to make sure phone powers up and battery is good.
Purchase new touch screen.
http://shop.ebay.com/p1i%20screen?_from=R40&_trksid=m38&_nkw=p1i+screen&_naf=1
Repair.
http://www.formymobile.co.uk/p1disassembly.php
Jun 27, 2009 | Sony Ericsson P1i
Unable to turn on and showing red light
the same happened to me the battery has had it get a new battery and it should work
Mar 15, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
Sony p1i display screen problem or software problem??
sorry to say the display ic might have knocked off. if soft ware problem u wont might be able to make and receive calls either
Oct 29, 2008 | Sony Ericsson P1i
Phone completely dead
This is a very odd problem with an even "odder" solution. When this happened to mine, I found a website that told me the following. I swear it works... eventually... probably.
Take the back off and just set it aside for a few minutes.
Now, remove the battery, and then put it back in, and then press the power button. If that does not do it, repeat the process...
... like 20 or 30 or 40 times. Eventually, the unit will make a (scary sounding) "pop" noise, and should turn on as normal.
I have had 3 Tilts. (I tend to be hard on phones.) Of those, two have had the "death" issue. Both were resuccitated this way, and worked just fine afterward.
Best of luck! Hope that helped. :-D
Jun 21, 2008 | AT&T 8925 Tilt Smartphone
Sony kp-61v35
Unless you can do tv repair your set has more wrong with it then something minor,it more then likely has a shorted Hori out put transistor NTE2973 and maybe open pico fuses.Take set to repair shop. ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Televison & Video
Sony Ericsson P1i Logo
250 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
