Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My washing machine leaks from the bottom while its filling. What could the problem be?
  • 176 Answers
Check all the hoses and watar pump
Posted on Sep 05, 2010
SOURCE: Kenmore Washing Machine
If not a hose leak, check for leakage around the water pump.  On our top-load Kenmore, the leak showed up at the front right of the machine.  Water was leaking where the pump slides onto the motor shaft.   Replacement of pump consists of: (1) unplug power cord and then remove 2 screws at corners of the dial/control panel to tilt it back, (2)  unplug wiring harness, (3) remove two spring clips holding white metal console to the frame then tilt console forward and remove, (4)pump was in front of machine with two black hoses attached via hose clamps - remove the spring clips at top & bottom of pump and remove the two hose clamps, (5) slide new pump onto shaft and reassemble in reverse order.
Posted on Oct 28, 2007
  • 311 Answers
SOURCE: washing machine is leaking from bottom
Take front off and see where leak is coming from. Most common is either a split hose or bad tub seal. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
  • 35 Answers
SOURCE: Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Posted on Jun 07, 2009
  • 4 Answers
SOURCE: Leak coming from the bottom of my washing machine
you probably have a tear in the bellow. cost to replace a few hundred dollars.
Posted on Jun 09, 2009
  • 76 Answers
SOURCE: water leaks out of bottom of machine olny when
This can happen when the rubber pipe that connects between the electric tap and the washing tank got disconnected .
Usually it happens after washing fully load machine with towel, blankets etc.
Open the back of the machine and check the rubber pipe, if loose or out of position get it back in to place and tight the metal bands that hold it .
Posted on Jul 15, 2009
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Water leaks (spewing) from sides of bottom of machine when it's filling up
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking. You may either need new tighner clips or to replace the hoses depending on how bad they are leaking. Another possibility is the water pump inside the washing machine could be broken and spewing out water.
Aug 31, 2007 | Malber WD1000 Front Load Washer/Dryer
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
There is a leak at the bottom of the washing machine. Water is coming out the bottom front and bottom left.
The leak is from the drain hoses or the fill pipes.
No need to worry.It's a common issue and easy
to fix of your own.
Sep 01, 2009 | Maytag Washing Machines
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Waher
quite possiblethat the tub itself is sitting to far foward, this machine fills from the back section above the tub, very possible as it fills its deflecting off the tub cover and unto the floor
Nov 26, 2008 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
