Question about NEC LT 220 Multimedia Projector
LT 200 blinking status light - fan not working
I have a new 'old stock' LT220. Used it twice for under an hour each time and now the blinking status light for a fan problem comes on. Is this a service item or is there an easier way to clear the fan error?
Thanks, Dave
This is usually an indication of one of three fans have stopped spining.
two are are mounted in a modular fashion behind the lamp housing and
the third is under the lense assembly. Not hard if your handy.
Posted on Apr 13, 2011
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Power light orange status light flash six times
This may mean your bulb is about to go out.
Jan 07, 2012 | NEC LT220 DLP Projector
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
Aug 25, 2011 | Mitsubishi Televison & Video
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
NEC projector LT220 - replaced bulb, works for 1.5 hrs then switches itself off
Hi Matt
There might be a couple of reasons for this problem.
Best is to start with the lamp - return the lamp to whoever you bought it from and insist on a another new one.
If the problem still occurs you should rather take the unit to a repairer - because it could be the Mainboard or the Ballast ( lamp's powersupply ) that is faulty and will need replacement or repair.
Check if your unit is under warranty - because the replacement of a Mainboard is quite expensive.
Apr 04, 2008 | NEC LT60LPK Projector Lamp for LT220,...
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Nov 22, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
PS2 Slimline Red Light Blinking
Try $99
http://www.frys.com/catreq/6746
Nov 18, 2007 | Sony PlayStation 2 Slimline Console
NEC LT 220 Multimedia Projector Logo
142 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
