Question about Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort coffee machine
hi when I use my steam a message is displayed OVERTEMPERATURE the machine seems to freeze and i cant use it for a long time
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Is it an expensive solution?
Posted on Jan 30, 2014
    Scholar:
  • 70 Answers
Sounds like the thermal resistor may be going bad.
Only way to get this fixed is having it sent out to a service center. Machine needs to be opened up and the resistor and a few sensor's need to be checked.
Posted on May 14, 2008
  • 1 more comment
  • Darren Jones Jun 16, 2011
    Not a sensor problem , main board fault , I have had this issue to fix a few times now.
  • thenak Aug 25, 2012
    Which components on the main board are the cause?
    XD6E35F2
I have a saeco magic comfort coffee machine and the display is showing " ventilate" . I have looked in the manual that comes with the machine and there is nothing about ventilate. can you tell me...
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a solenoid for the water. That would have to be fixed by a service unless you are very handy.
Feb 11, 2011 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
Hi I have Saeco Magic Comfort. The ventilate warning is on and no matter what I do I cant get it to go away.
HI Have you pushed the button with the water drop icon? If you have you have a bad flow meter or the solenoid to the steam valve is stuck or you have a plug in the tip of the wand. Its hard to diagnose the problem without seeing the machine.
Sep 23, 2010 | Saeco Magic Comfort 103467 Espresso...
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
"Steam" function not working properly on Saeco Magic Comfort Plus
Most likely the nozzle is plugging up. Use a piece of wire and run it through the nozzle a few times.
please mark this answer as a fixya
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Error message on screen VENTILATE
put a cup under the steam pipe.
If you have a new model of Magic Comfort the you have to press the right lower button, if you have a old vrsion then you have to press the button under the meny button.
Make a cup of water.
/Mirran
Aug 31, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
336 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
