Question about Linksys Wireless-G WRT54G Router
When i put in 192.168.1.1 in my browser and then it ask me for user name and password..i put in admin in both fields or one then the other..lit still won't let me access the router. please tell me how i can change my user name and password so i can make my network secure. Thank you
  • Linksys Master
  • 7,733 Answers
Changing the Router's Password
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click on the Administration tab.
Step 3:
Enter the new password in the Password field and Re-enter to confirm.
NOTE: The image may vary depending on the model number of the Linksys device.
Posted on Oct 29, 2010
  • Anonymous Oct 29, 2010
    Title: Changing the Linksys Router's Password
    Article ID: 3976
    This article will guide you on how to change the password of your Linksys router.
    NOTE: The default password of your router is
    "admin" and no User name. It is recommended to change the Password for
    security purposes. If you forgot your Password, press and hold the
    reset button at the back your router. To learn how to reset the
    Password of your router, click here.
    Step 1:
    Step 2:
    Step 3:
    NOTE: If the window on your router's web-based setup page looks different, click here.
    Step 4:
    Click .
I can't connect to my internet. I don't know the correct password.
You will need to login to your wireless router to get, or set, your network password. A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information. User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Nov 17, 2014 | Roku 3
Just installed roku. How do I find password for Home_B698
You will need to login to your wireless router on your computer to get, or set, your network password for "Home_B698". A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information... User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
Nov 15, 2014 | Roku Streaming Stick
How to change password to small
Open your preferred internet browser and enter "192.168.1.1" in your web browser's address field.
When login dialog box will appear,leave the user name field empty. Input "admin" in the password field. Click "OK" to log into the router. The blank user name and "admin" password are the default configuration settings for your router.
Click "Security". Type the new password you want to assign to the user account. Enter it again in the "Re-enter to Confirm" field. Click "Apply".
Close your internet browser after you have completed the password change to protect your router from unauthorized access.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 19, 2012 | Linksys Wireless-G WRT54G Router
How to change wifi name in router
The wifi name you are referring to is called SSID, service set identifier. You can change that by logging onto your routers Web based utility. Open your web browser and type in 192.168.0.1 and it will ask you for a user name and password. If you keep the default user name and password the user name should be admin and the password is blank, meaning there is no password set up. After logging on, click on top tab "Setup" and on the side menu "Wireless". You should be able to change the SSID by typing in a new name in the field "Wireless Network Name". Make sure you save the changes! This should then change the name.
Mar 25, 2012 | D-Link DIR-600 Router
How can i open my belkin router upnp
You will have to log in to the setting of the router. This is accomplished by typing the ip adress of the router usually 192.168.1.1 or 192.168.0.1 into a web browser. It will then ask for a user name and password: the default user name and password for belkin routers is: User name: Admin Password: (Leave the Field blank). Then you can enable UPnP in there. UPnP stands for universal plug and play :) Hope this helps. Thanks
Dec 27, 2010 | Belkin (F5D7230-4) Router (587009)
I can not configure the router. I need help
Plug your computer directly into the router. and then go to a web browser (Firefox, internet explorer, or safari) and type in 192.168.1.1, if that doesn't work try 192.168.0.1. It will ask you for user name and password. User name usually is: Admin. Password is either: Admin, Password, or leave the field blank :) Best luck to you :)
Dec 27, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do i get my password from my linksys
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
Jul 10, 2010 | Linksys WRT160N Wireless Router
I reset the WRT400N password, then entered the default password admin and it does not work
here is the link to the user manual ...if you changed the admin password and cannot get in you will have to reset the router and put all new settings back in
the default user name is : wrt400 or wrt400n
and default password is admin
To access the web-based utility, launch the web browser on
your computer, and enter the Router’s default IP address,
192.168.1.1 or http://wrt400n.com in the Address field.
Then, press Enter.
A password request screen will appear. (Non-Windows XP
users will see a similar screen.) Leave the User name field
blank. The first time you open the web-based utility, use
the default password admin. (You can set a new password
on the Administration > Management screen.) Click OK to
continue.
http://www.abt.com/images/products/PDF_Files/wrt400n_manual.pdf
Feb 17, 2010 | Linksys WRT400N Router
I have an iPod touch and it asked for login and password and I did not put one on my router. How can I get in?
Use your browser and type into the address bar:
http://192.168.0.1
User name is "admin" (no quotes)
and password field is left blank. Let's pretend that you wanted to log into the router...right?
Jan 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Default password
For DLINK ROUTERS there is no default user name.
There is however a default Password and that is admin
So when the authorization page appears leave the user name field BLANK and put admin (all lowercase) in the password field.
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
