Question about Sharp R-510HW Microwave Oven
Sharp R 1470A door panel
I need to replace the front panel in the door of my microwave. It looks like the panel may slide out for replacement. Do you know if this is the case? Do you have any diagrams that would show how to accomplish this?
Thanks!
Diana
  • Sharp Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
There may also be a piece on the side edge of the door which needs to come off, too.
You can probably find an exploded view by entering your model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 12, 2008
We have a sharp model 1470a carousel. we can enter data on the keyboard but the mwave does not staRT. eX: HIT 'BAKED POTATO', IT DOES NOT START. HIT 15 SECONDS AND THEN RUN AND IT DOES NOT START....
I would suspect that you have a bad door switch or mount, or perhaps the "Start" pad on your keypad is bad.
The quickest way to check is to hit the "Minute Plus" pad and see if the oven cooks.
If not, it's a door switch or switch mount issue, either the top or bottom one. See my complete text file on door switch trouble here.
If it cooks, then your keypad is defective. It is part number FUNTKB107MRE0 (note zeroes, not ohs) and you can order one from Encompass here or you can call them toll-free at 866-779-5835.
Oct 17, 2011 | Sharp R-1470 Microwave Oven
Can you please send me an instruction manual for sharp carosel microwave serial number R-1470A , bought it used with no manual ,
mcdevito75 here, Best bet, try to contact Sharp online, or see any store that sells Sharp microvave ovens in your area for contact info.
Jul 09, 2010 | Sharp R-1470 Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Can I replace the front door panel kit myself?
No, it needs a special aligning for avoiding the microwaves leaking outside the oven.
If you replace it anyways, check with a microwave detector that there isn't any leak.
Oct 27, 2009 | Sharp R-1501 Microwave Oven
Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Sep 28, 2009 | Sharp Microwave Ovens
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Sharp R-510HW Microwave Oven Logo
272 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
