Question about Sunpak 622 Super Pro TTL Flash
What is the trigger voltage of the sunpak 622 auto pro ? can i fire the sunpak 662 auto pro on a Nikon D6 digital body using a pc socket adapter attached to the hotshoe? will the trigger voltage be compatible, nikon tells me that the max voltage on the D6 is 240v,
  • 3 Answers
Sunpak 622 Auto Pro has 6.5 - 8.0 V trigger voltage.
It should be OK for Nikon D6
Strobe TriggerVoltages
Posted on Aug 30, 2014
kalaci
  • 30 Answers
SOURCE: I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Posted on Feb 18, 2009
SOURCE: SUNPAK 622 SUPER
ToCAD America Inc.
53 Green Pond Road
Rockaway, New Jersey 07866, USA
Phone: 973-627-9600
Fax: 973-664-2438
Email: info@tocad.com
$ 111.00 to look and additional for parts and labor. Expensive.
Probably cheaper to buy one off eBay.
Posted on Mar 25, 2009
  • 302 Answers
SOURCE: Will my sunpak PZ4000 flash trigger voltage harm
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Posted on Oct 20, 2009
Testimonial: "Thanks for info.Sorry I could not get back sooner but I lost my Wife recently.Thanks Cecil"
  • 65 Answers
SOURCE: On the 622 pro Sunpak
Sunpak TR-Pak II a NiCad flash battery pack with charger and Quantam battery both has cords for 622.
Personally I have taken out wire pair from removable battery pack of 622 and connected to 4 cells of Nicd type D battery pack made at home.(I placed that in my belt bag).
want more details ,feel free to email at bforbay@gmail.com
Posted on Mar 30, 2010
  • 102366 Answers
SOURCE: I would like to use
According to the list at http://www.botzilla.com/photo/strobeVolts.html , it's your call. The flash's trigger voltage is right on the border. Depending on the individual camera and flash, it may or may not be safe. Personally, I wouldn't risk it without something like the Wein Safe-Sync in between to buffer the current.
Posted on Mar 03, 2011
Testimonial: "Thanks for the testimonial I will definetly follow you advise. "
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
Will sunpak 622 flash work with Nikon 5200?
You will need a "Hot shoe to PC connection adapter" to connect the PC sync cord to your camera
Dot Line Nikon Hot Shoe to PC Connection Adapter
Jan 29, 2014 | Sunpak 622 Super Pro TTL Flash
Can i use sunpak auto 30 DX thyristor to nikon d7000?
According to this list the 30DX's trigger voltage is borderline for use with digital cameras. You may be able to use it with no ill effects, or it may fry your camera. It depends on the particular unit.
May 12, 2012 | Sunpak Nikon Auto 30dx Thyristor Shoe...
I have a Sunpak auto 622 pro system flash. I put this on the shelf about twenty years ago and it was working perfect. I now want to use it with my Olympus E520. The flash seems to work OK except the auto...
For something of that age, repair may not be an option due to lack of spares. May be better to replace it. Be wary of using it on digital anyway, as the high trigger voltage may fry the camera's internal electronics.
Jun 16, 2017 | Sunpak 622 Super Pro TTL Flash
IS THE VOLTAGE FROM A SUNPAK 622 SUPER SAFE TO USE WITH A NIKON dD 70
I have read reports of this working. To be safe you can cover everything but the center pin with electrical tape, or you can buy surge protectors for flashes to protect your camera.
Mar 03, 2011 | Sunpak 622 Super Pro TTL Flash
I would like to use a sunpak 622 super with a sync connect to the hot shoe. Is the voltage too high for my nikon D 70 DSLR My e -mail is ml1089h@stx.rr.com
Sunpak 622 Recycle Time w/ Batteries vs AD-26
I had the same problem - 10-11 secs on 240VAC. My solution was to get the Quantum Turbo SC for $450. It yields ~3sec recycle times. This pack for $150 should play nicely as well: http://www.adorama.com/JTMBPN.html?searchinfo=jtl+lancer+battery+pck It was out of stock at the time. The Sunpak TR2000 is $250, but it's Ni-Cd while the others are NiMH. There are other HV packs capable of powering the 622 w/ the fitting cable like Lumedyne IIRC. The AD-26 is still useful for non-action photography. The fastest time I saw posted is 1.5 secs, but it's a DIY job (search 'sunpak 622' on flickr). HTH,
Szilard
May 15, 2009 | Sunpak 622 Super Pro TTL Flash
I have a sunpak 622
Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
D40 compatability with Sunpak auto 144D flash
the voltage on the flash hot shoe contacts (center pin and rail connector) can be as high as 140V DC and this voltage is backfed into the camera through its hotshoe connector. There are adapters that can be bought that isolate this voltage that go between the flash and the camera, but different camera makers have different ratings for the flash voltage. My Vivitar 220 has 122 volts across the contacts from 4 AA batteries! Canon recommends nothing over 6v but Fuji says 60v and others dont say anything. SLR's used a mechanical trigger, modern digi cams use an electronic trigger. Also Digcams use electronic metering for exposure so they dont take into consideration the addition of another flash unless they do a preflash, TTL metering and the flash unit is capable of recharging in about 1/10th second. YOu may have to do some post processing or set the camera on manual to adjust the exposure.
Jun 08, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Sunpak Auto zoom 3000 thyristor
You can use the Sunpak on a bracket with a "slave trigger" and fire the slave with the Nikon's pop-up flash. I do the same with a SunPak 3600 Auto Zoom. Just remember not to have the red-eye feature operating. Those little slave triggers are only a couple of dollars and I already had few brackets.
Jun 03, 2008 | Cameras
Sunpak 622 Super Pro TTL Flash Logo
346 people viewed this question
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
