Question about Samsung HLR5667W 56" Rear Projection HDTV
I have a Samsung HL-R5667WX/XAA Rear Projection HDTV that has a bad color wheel assembly (loud buzzing, not fans). Problem is, two parts are listed one for chassis (L3) and one for chassis (L6). How does one identify the chassis to ensure the correct part?
  • psienergos Sep 16, 2010
    Solved this one on my own. If you remove the plastic access cover (the entire cover, not just the one that gives you lamp assembly access), there is a label that will identify the chassis as either L3 or L6.
    Remember to look before you order the part!
I have the same TV
Posted on Sep 15, 2010
  • BW107 Sep 15, 2010
    I have the same TV
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
Fan is making a loud noise and picture is fuzzy
That is more likely your Color Wheel is bad than a fan. Go to www.encompassparts.com and enter as guest, put you model number in and see if its still available as a single unit or a complete engine assembly.
Dec 04, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung Hl-P5063wx/xaa that I recently replaced the bulb (3 months ago) then a week later replaced the color wheel. I now get only sound no picture whatsoever. I hooked up a different tv to the...
Remove projector assembly and clean out dust from cooling fans inside of it. It will require some disassembly. Then have capacitors checked on the power supply.
Apr 29, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Loud buzzing noise and no color. Does this mean the color wheel is bad. Thanks
Yes,the colors wheel is worn out,U have no machanical skills,hire a tv repairman to change this.Require take out many parts before can even to get to the colors wheel,to replaced.
Mar 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Cooling fan buzzing
Yes,don't do it yourself,and you need to have repair tech. asap,cause if the cooling fan is not working properly,that could trigger other parts in the tv to be malfunction.
Hurry,just it fix!
solutiondoct
Nov 01, 2008 | Samsung HL-R6167W 61" HDTV
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
313 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
