Question about Optoma MovieTime DV10 Multimedia Projector
No signal I connected the projector to laptop, but it says no signal source lock...help I rebooted but still no signal
  • 4,234 Answers
The output video needs to be enabled on the laptop. Normally this connector is not active. There should be a function key that has the outline of a CRT screen on it. Using the ctrl key and that key at the same time will toggel the output video connector on/off. If that does not resolve the problem, please update this with your exact setup including cables.
Thanks,
Dan
Posted on May 12, 2008
I have been using this Acer projector but it suddenly locked. The display shows the acer logo, no signal and a lock. I can not unlock it. What must I do to unlock it. I am not using any password.
it means the projector
locks on this source type and there is no such type of input
signal found,
so you need to try new input source type . means : if you use for example VGA, try to use other input type such DVI , HDMI
Nov 10, 2016 | Acer Computers & Internet
No picture
Hi, Possibly either of 2 reasons: 1. Your player is not sending any signal to the Optima meaning it is the one in question and not the projector; or 2. Your Optima lost its input signal, go through the signal source selection menu, try manual selection & set it to where your source/player is connected. Hope this works out for you, if not pls post again . Good luck and kind regards.
Aug 03, 2007 | Optoma H31 Multimedia Projector
MY VIEWSONIC PJ402D DLP PROJECTOR WILL ONLY DISPLAY IN BLACK AND WHITE.
If you are connecting the projector to the signal source via S-VIDEO cable this not uncommon. It usually happens when one of the connectors or the cable is broken. Try a new or different cable. If problem persists examine the connectors on both end of the cable and the one in the projector as well as the one in the signal source(pc, laptop etc) to see if there is a hardware fault. If all is good then the problem is internal with the S-VIDEO connector. In that case your other option is to use VGA.
Have a good day, hope this helps.
Nov 03, 2011 | ViewSonic PJ402D DLP Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
I am trying to connect it to a dell laptop with a vga connection and the projector says no signal.
make sure the computer is set to extended desktop or clone desktop. make sure the video output (resolution, refresh rate, etc) is in the range of the projector. If the Dell was powered up when you plugged in th eprojector, reboot. make sure the active input source is the one that you connected to the computer.
Mar 06, 2010 | Mitsubishi XD205U Multimedia Projector
No signal from laptop even though it is connected I have attached an apple laptop to projector and no image from the computer is being shown I have pressed source and it says no signal. The computer is on...
this is going to be a bummer, but have tried to use another cable? to check if there is an issue with the cable try using another device that uses the same. if it works with it it may depend on the configuration of on your operating system which may vary
Oct 09, 2009 | Epson PowerLite® 83c LCD Projector
No Signal when plugging into laptop
On your laptop you have the ability to toggle the external display on/off/both. On several laptops I see, it is a combo of teh Function Key+F4 (or F5). The key for your laptop (you did not provide type) should be marked with an image of a projection screed or a monitor in a color matching function key; often blue.
With everything connected, press these keys to toggle from Laptop Display Only to Projector Only to Both.
If the problem is not your laptop, then verify the input source that the projector is looking for via it's menus or a button on the remote. Toggle the source if required.
Aug 05, 2009 | Sanyo PLC XU35 Multimedia Projector
SOURCE PROBLEM
Hi John
Is your Projector's source scan swithed on ?
Does it pick up a signal when you press the source button ?
Apr 20, 2008 | Canon LV-7230 Multimedia Projector
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Mar 28, 2008 | HP VP 6210 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
563 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
