Question about GPS
How do I charge up the GPS apart from through the cigarette lighter of the car? Is there an insteruction leaflet available?
  • 1,606 Answers
Usually there are 3 ways to charge. One is with the car adapter. The other will be a plug in adaptor that goes into the house power outlet. And the last will be charging when plugged into the USB port of a computer. The fastest is the house charger, the second your car, and the third is the usb. It will take 1-2 hours or so on the first two and maybe 3-5 on the usb.
You haven't mentioned your brand or model of gps unit so I can;t give you the exact webpage to go to. If you go to the brand webpage ie go to www.garmin.com if it is a garmin or www.tomtom.com if it is a tomtom and so on. Then look under products to find your model. There will usually be a acessories button or tab that shows you all sorts of ways to spend your money. That should show you what chargers they offer. They will also have a support page that you can download the manuals and brochures. If worse comes to worse don;t be afraid to call them or the store up and ask which one you need.
If you live where there is a bigger store they will usually have the chargers. The cables are just standard usb data cables. The charger will be $10-$30 and the cable should be about $5. It's actually handy to have all of them. Then you don;t have to leave a computer running and can quickly charge it in the house or elsewhere.
Posted on Sep 05, 2010
How I can recharge the battery?
You can charge the battery by connecting the satnav to your computer with the mini USB lead for 8 hours with both turned on. You can also charge it by leaving the car charger connected to it and plugged into the cigarette lighter socket of your car for 4 hours. There must be power going to the cigarette lighter socket. On some cars power is always available at the socket but on others it is only available when the car engine is on.
Jun 12, 2011 | Garmin nuvi 205W GPS Receiver
I need to buy a plug for car . It is not charging tne GPS
You can get accessories including the car charger from http://www.gpsnow.com/Garmin_nuvi_255_Accessories.htm
However it's likely that if the car charger is not working that the fuse is blown. The fuse is in the plug that goes in the cigarette lighter socket. To get at it unscrew the ring at the end of the plug. Be careful not to lose the small metal tip. When you unscrew the ring the plug comes apart and you'll see the fuse. You can get replacement fuses at any shop that sells garmin satnavs or car electrical accessory shops.
Before changing the fuse make sure your cigarette lighter socket is working by testing it with the cigarettel lighter or some other accessory.
Jan 14, 2011 | Garmin nuvi 255W GPS Receiver
My nuvi 760 doesn't charge in the car. is there another way to charge it?
It can be charged from a computer. Connect it to your computer with the mini USB lead and it will charge. It takes about 8 hours compared to 4 hours with the car charger or with a mains charger.
If your car charger isn't working it's likely that the fuse is blown. I presume you checked the cigarette lighter socket first and that it's working. If not try something else in the socket and make sure that's not the problem.
At the end of the charger lead plug, that goes in the cigarette lighter socket, there's a ring. Unscrew the ring and the plug comes apart. Be careful not to lose the silver tip. When the plug comes apart you'll see the fuse. You'll get a replacement in any car electrics shop or anywhere that supplies satnavs. I hope this solves your problem.
Jan 08, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
I have garmin gps it not chargeing my car onl by computer whe?
It's most likely that the fuse in the charger has blown. The fuse is located in the plug that goes into the cigarette lighter socket. On the end of the plug there's a ring. Unscrew the ring and it comes apart. Be careful not to lose any parts when you open it. You'll see the fuse which needs to be replaced. If this does not solve the problem it's possible that the cigarette lighter is faulty.
Oct 11, 2010 | Garmin nuvi 255W GPS Receiver
Cigarette lighter not working in my car
have to take dash apart use the outlet in the rear right end
Jul 27, 2010 | 2001 Plymouth Neon
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
100 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
