Question about Nokia 6300 Cellular Phone
Insert sim hi can u help me on this?..evrytime i open my cellphone..its says insert sim.what does it mean? thanks
    Sniper:
  • 57 Answers
It means your phone is locked . first you unlock your phone after that your phone is unlock . after unlocking you can use any gsm sim card in your phone . visit here this site and get your imei unlock code. i hope this will help you.
Posted on Sep 23, 2011
    President:
  • 1,017 Answers
It means that your phone is not reading the SIM card. The physical contact points on the SIM card may be worn (if it's been removed often) or it may be a SIM card from a different network to what the phone is programed for.
If it's the latter, to remove the lock put in place by the Network Service Provider, you have to know which Network it is and the country it's from.
The IMEI (International Mobile Equipment Identity) number, is required to unlock the phone. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the make and model of phone, the network that the phone is locked on, and the country the network is from. Then I will give you the codes to unlock the SIM card.
"The soul is the spirit of the body, and music is the spirit of the soul."
Posted on May 12, 2008
I want to use my cellphone from japan and iwant to use here in the philippines with use a sim card globe.i cannot open.pls.help me for openline my phone use a sim card globe my cellphone is disney mob
You can go to greenhilss shopping center in San Juan , Metro Manila . There are many service center there that fixes cellphones . They can configure your phone "open line" so that you will be able to use your globe sim card.
Thank you
Dennis
Sep 02, 2014 | NTT DoCoMo,Inc. Computers & Internet
INVALID SIM
This may be because of your damaged SIM. Try the following:
1. Check whether your SIM is rejected by just putting the same SIM in another phone. Also, check if your SIM is a valid GSM compatible SIM.
2. Check if that your phones SIM slot is fully operational.
3. Check if you have correctly inserted the SIM.
Hope this may help you. Happy New Year to you too.
Jan 01, 2012 | Nokia Cell Phones
I have nokia 5230 mobile but after inserting india sim it shows the sim card not valid. could u solve my problem plzzzzzzzz Thanking you
Good day. Your phone was locked to the previous network provider, meaning you can not use any simcard, unless if you insert the previous sim. If you know the phone security of that phone, you can manually reformat by typing this to your phone *#7780. Then if still cant fix it, i might suggest you to reformat using pc. Or go to your nearest cellphone technician to convert it to open line or to unlock. Thanks
Sep 11, 2011 | Cell Phones
2730c this mobile on normal.ok,after 5 seconds it show simcard registration failed in any working simcard.plz help me.thank u
hi try to my advice if your cellphone is sometimes indicate insert sim.you need to go cellphone repair shop its hardware defect cellphone.thanks
Jul 29, 2011 | Nokia 2730 Cell Phone
Nokia 1100 it showing that sim not valid now what can i do that
You can try a different sim to check if the problem is within the phone. If any case the cellphone recognize the new simcard it only means that the 1st simcard that youve use is faulty.If the cellphone still wont recognize the new sim card then it only means that the problem is within the phone. You can check if the phone still have a warranty for repair free of cost or bring it to a cellphone technician to fix it
Remember insert a SIM Card that is supported by your mobile phone it may be locked to a certain provider
Thank you for using Fixya
Jul 29, 2010 | Computers & Internet
Insert Sim problem on Nokia 1650
hi, it means the sim is not properly placed in it possition..what you can do in the main time is to change the case of the phone, so that you won't need to be using rubber band to hold phones together.
Jul 09, 2010 | Nokia 1650 Cell Phone
Always show the message 'insert sim card', When I refitted the SIM and turned back on, I had no network coverage. it always again n again n again..
Hi,when a phone does that, it means that the memmory of the phone is malfunction and it needs to be restored..
To be able to restore back the phone memory, you will need to flash the phone memory.
The links below will give you a guide line on how to flash the phone memory .
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Sony Ericsson K530i Cellular Phone
It alway diplay No SIM Card inserted even when there SIM Card in it.
Solution, try putting a paper behind the sim card before placing it in the cellphone. The paper adds thickness to the sim card and makes it touch the connectors in the cellphone.
May 02, 2009 | Cell Phones
Insert sim
Its possible that the sim card on your phone is not properly placed or the sim card that you own has some problems already.
Try to reinsert your sim card, this time make sure that it is properly placed. If the same happens, try to use a different sim card on your phone. If there are no problems, that means your sim card might be busted already. If the same happens with another sim card, then it is possible that the slot for the sim on your phone is defective or dirty. You may need to have it checked. :)
May 12, 2008 | Nokia 6300 Cellular Phone
HAVE PROBLEM
weel I suggest you select a main sim on sim menu. Put your simcard in the left side if you have dual sim slot then open the cellphone, go to menu and select sim switch, then select the main switch. it will automatically restart your cellphone. after that you wait and see good signal bar and your operator logo what ever it is. now its ok. hope it will help you......
Mar 08, 2008 | Nokia N95 Cellular Phone
Nokia 6300 Cellular Phone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
