Question about Garmin nuvi 260W GPS Receiver
I have a garmin nuvi and I had it in the charger and I took it off and then gives you the opinions of turning on or off I press off but now I am trying to turn it on but it will not turn back on. Can this be fix?
  • Garmin Master
  • 589 Answers
Are you saying that you remove it from the Suction cup charger its asking that.....
Thats normal on the Nuvi units when you release it from the cradle it will ask to stay On or Off..... this automatically creates teh last positon your car was in whne you take it off the cradle.... the last positon will store in your favorites..( its a great tool if you forget where you parked your car, just look in your favorites then Last Position it will then take you there )
To power on the Nuvi unit again there is a sliding switch on top of unit.. push left to power up.
Posted on Oct 24, 2010
My screen is very dim. I turned brightness as high as it will go, but still dim.
Part of your LCD is not lighting up. This tends to happen as the nuvi 200 series units age. Garmin can repair this at $69 flat rate. In my opinion it isn't worth it because you can go out and buy a newer better model for that price. But if you want it repaired give garmin a call at 800-800-1012.
Sep 24, 2011 | Garmin nuvi 205 GPS Receiver
My garmin 1350T just shut off and will not turn back on
If your garmin nuvi shuts off and refuses to turn back on, even if you press the power button, then it means the battery is weak and cannot power on the nuvi. Try to take out the battery and reinsert it back it then try to turn it on to see if it will turn on, if it does not still turn on, then borrow a battery from a friend and use it to test your nuvi, if it powers on, then your battery is either weak or dead.
Insert the battery into another gps and charge it with another charger for about 2 hours to see if it will hold a charge, try to use it to power your nuvi on to see if it will work. If it works, then it means your charger was not charging it initially. That means the charger is bad and need to be replaced, but if the battery does not turn on your nuvi after charging it for about 2 hours, then it means the battery is bad and need to be replaced.
Either ways both the charger and the battery need to be checked to know which of the two is faulty.
Carrying out the test will show you the faulty component and the solution is for you to replace it with a new one.
Hope this was helped you.
Dec 24, 2010 | Garmin nuvi 1350 Car GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 350. It suddenly quit. It would not power up. I bought new car charger and wall charger specifically for nuvi 350. Both charger would not power up the gps at all. Is my battery dead or...
I would say this is not a battery problem. A Nuvi will power up even with the internal battery disconnect (done it many times myself ) when connected to an external power source. Please see this link about Dead Nuvi's. Have you tried pressing the reset button behind the antenna?
http://www.sharc.net/gps_dead.htm
- Jim
Jan 18, 2010 | Garmin nuvi 350 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Feb 21, 2009 | Garmin Nuvi 255 GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
Will Not Charge
You're still in warranty. Send it back to Garmin.
Jul 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
