Question about Cycling
Nokia 1202 dead deep the water &shot - Cycling
  • 3 Answers
Down water after died
Posted on Oct 07, 2010
1202 dead solution
charge it longer and try not to use it while its charging , that makes the battery weaker
Mar 22, 2014 | Nokia 1202 Cell Phone
Nokia 1202 imei351933o34736899 unlock code
Hi, You can get the unlock code for a Nokia 1202 from www.TheUnlockSpot.com at affordable cost by specifying your network and country too.
Steps for unlocking a Nokia 1202,
1 - Switch on your Nokia 1202 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1202.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1202 would then display the message "SIM Restriction Off" and will be unlocked!
Dec 16, 2012 | Nokia 1202 Cell Phone
Nokia 1202 dead solution
1202 dead solution plz......
Dec 28, 2011 | Nokia 1208 Cellular Phone
How to unlock security code of nokia 1202?
Normal Reset
You can use the *#7780# sequence. It will restore ini files from ROM having entire data of your mobile phone (themes, 3rd party applications, video, photos, and music files)
Deep Reset
You can use *#7370# sequence. That will properly formats the phone memory. Default files are destroyed and rewritten. One thing should be considered here that the data found on memory card will not be altered ...
OR
There are so many ways to get access on your phone.You can open it with the help of ways, sometimes it can be opened manually and one of the method through the software to reset it . The users commonly use the software utility to unlock or reset the phone. It's depends on you that what you want to choose to reset your code.One of the popular software to reset your Nokia code, Master Security Code which can be used to unlock or reset your current situation and then you can easily access your pone after assigning a new one code..
Sep 09, 2010 | Nokia 1209 Cell Phone
1202 nokia dead from water falling whaen i flash
hi,
clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure..
using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker...
in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya..
goodluck..
Jun 16, 2010 | Cell Phones
Solution for nokia 1202-2 which reads contact service?
my problem is contac service for NOKIA 1202,i need a solution....?
Apr 26, 2010 | Nokia Cell Phones
How to unlock nokia 1202-2 with mastercode
how to unlock nokia 1202-2 SECURITY CODE, i forgot my security code. its IMEI iS 353195036937382
Jan 09, 2010 | Nokia Cell Phones
Cycling Logo
198 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
