Aiwa AM-C80 Personal MiniDisc Player
Problem for Aiwa AM-C80 Personal MiniDisc Player
Aiwa MD AM-C80 remote malfunction
By Jimmy NY - usenet poster
Hi there all,
Was given a MD player as a hand-me-down.
The player seems to malfunction when the remote is plugged in?
It changes mode randomly , and none of the player controls work. If I
unplug the remote then they seem to work again.
Any ideas what could be wrong here.
Cheers
Conrad Strydom
Solution #1
posted on Aug 07, 2005
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
If I had to hazard a guess I'd say the remote is faulty, Possibly a bad
cable.  Other possibilities include a falty connection inside the player
But first thing I'd check is the remote itself.  To do this there are
three ways
Method 1: Find a friend with another A-C80 and try your remote in his box
Method 2: Same friend, his remote your box  (note, combining 1 and 2 is
kind of like belt and suspenders, but if you do that you totally
eliminate one or the other as the problem beyond any shadow of a doubt
Method 3: Send both to Aiwa factory service and let them figure it out
Note 1:
Try this... First  inspect the plug, If it is a flat circuit board with
traces use a pencil eraser to gently "Erase" any dirt that might be on
them and polish them up nice and shiny.
Then try try plugging it in and unplugging a dozen or so times with the
unit completely power off, I mean remove batteries off, I want it so far
off that you can't even turn it on
Dirty contacts on the remote plug or socket could cause this too,
Was this helpful?
Yes
No
Solution #2
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
Hmmm , thanks John.
Further investigation has shown that any headphone plugged into the jack
, with - or without the remote , will cause this malfunction on the player.
Could it be this "dirt" you where referring to causing some sort of a short?
Cheers
Conrad
Was this helpful?
Yes
No
Solution #3
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
Not likely, since the only thing the headphone and remote jacks share is
  a neighborhood (they are next door to each other) I'm assuming Aiwa
uses the SONY style where the remote plug is a headphone plug with a
blade next to it, the blade is the remote plug.
This sounds more like a problem with the circuit board inside the
recorder, Possibly a bad solder joint, broken trace or debris on the
board, In any case, I would suggest service for the unit under these
conditions.
Was this helpful?
Yes
No
Popular Solutions for Aiwa AM-C80 Personal MiniDisc
Questions and Unsolved Problems for Aiwa AM-C80 Personal MiniDisc
Do you recommend Aiwa AM-C80 Personal MiniDisc Player?
Answer
Answer
My audiophase portable CD player is playing CD's. sometimes it won't start playing them and... (More)
Answer
Aiawa cd3, cd will grab cd's, spin 4-5 times then stop. What's going on? Is it fixable. Worked well... (More)
Answer
will not play cd or dvd wont read that there is a disc in would this mean that the it is stuffed ,,... (More)
Answer
How do you respond back and forth on this site? I don't see any 'answer' or 'reply' buttons or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Personal Audio... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
