Question about Car Audio & Video
Kenwood kdc-mp146,has wood protect on screen - Car Audio & Video
  • 78 Answers
SOURCE: Kenwood car stereo KDC-W3534 : warning message PROTECT
This is a safety feature and it usually suggest that there is a problem with the internal amplifier, it could also be a trapped speaker wire. Remove the radio and check if any of the cables have been damaged and if you power up the radio with the speaker plug disconnected that will tell you if the fault is in the car or the radio
Posted on Dec 23, 2007
Benimur
  • 6966 Answers
SOURCE: My kenwood head deck
A "PROTECT" message/display normally indicates a problem with your speaker or your speaker wires. Pls check for any open or shorted (busted speakers) or if any of the wires are touching the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
  • 147 Answers
SOURCE: Kenwood kdc-148 is in protect
A car audio component like an amplifier (or in this case a headunit) is most likely to go into protection mode when there is a short in one of the speaker outputs-- in other words, if the + and - ends of one of the speaker leads are touching, this can cause damage to the internal amplifier of the unit. Some units will respond by putting the amplifier into "protection" mode, so that it does not damage itself. Check connections on the back of your unit, or take it back to the shop that installed it.
Posted on Mar 04, 2011
i had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Posted on Aug 28, 2008
SOURCE: I a kenwood KDC-3037
i have a kenwood kdc S3009. All I need to know is how to set the current time
Posted on Sep 22, 2010
How do I install KDC-MP146 ( kenwood mp3/cd tuner) personally?
depends on the car, but id say go buy the wiring harness adapter from best buy or radio shack for your particular car. wire it onto your stereo then plug it directly into the old radio harness in your dash.its really not that hard unless you have a newer car with factory gps, or whatever.
Feb 27, 2011 | Car Audio & Video
Installed a Kenwood KDC-MP146 and each time i turn off the car ignition I have to reset the stations, clock and cancel the demo mode. Is this a wiring problem and have i incorrectly connected the system?
you have connected the constant power (battery (yellow)) and the ignition wire (red) around the wrong way. this is a very common mistake that I come across and easily rectified. it should take you about five min to fix.
I hope this helped and please dont forget to rate my solution.
cheers
Jan 15, 2011 | Kenwood Car Audio & Video
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
Dec 18, 2010 | Kenwood KDC-135 CD Player
MY kenwood KDC-W3044 is showing protect on the screen....... what should i do to remove??????
Dec 11, 2010 | Audio Players & Recorders
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
Problems with Kenwood kdc-532u car audio
Find the short in your speaker wires.
Good Luck
Leadispenser
Jun 17, 2008 | Kenwood KDC-MP235 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Mar 20, 2008 | Kenwood KDC-MP235 CD Player
Car Audio & Video Logo
308 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
