Question about Sony CDX-M50IP
Sony CDX-M50IP MARINE RADIO. Had volume turned up to 32. Radio turned off on its own. Now turns on for a split second on its own and turns off. 2 minutes later, does the same. Tried reset, no help. unplugged all power to unit, no help. charged the battery to 14.4 volts, still no help. Any ideas would be great. I remove the faceplate to keep it from powering up on its own. I think the problem is in the faceplate, volume control. Thanks!
  • 3 Answers
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Posted on Mar 13, 2009
  • 150 Answers
SOURCE: radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
Posted on May 12, 2009
  • 655 Answers
SOURCE: My Sony CDX-C680...
Hello greggerika,
It's possible that the "illumination" wire is not connected or connected improperly. It's also possible that the front panel electrical connections are not making proper contact. Remove the front panel and gently clean the contacts with a pencil eraser.
Also, the CDX-C680 allows you to select either green or amber illumination. One or the other may be defective. Try changing it. Press SHIFT - press "3" (set up) three times - press "5" (right arrow) to change the setting. Also check the setting for "dimmer". ON will result in a dimmed display at all times. AUTO will dim the display whenever the headlights are turned on (if the wiring is connected properly). OFF will result in the brightest display at all times.
Hope this helps.
Posted on Jun 14, 2009
SOURCE: Sony CDX-GT30W faceplate
I have a faceplate for a sony cdx-gt30w. You can have it for whatever it costs for me to mail it to you. Do you still need one. I noticed you posted this a loooong time ago.
Posted on Aug 18, 2009
SOURCE: my sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Posted on Dec 07, 2009
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
Mar 15, 2009 | Sony Car Audio & Video
Can't figure out how to change the time
Press DSPL for 2 seconds
Press the + or - volume buttons to set the hour
press SEL
Use the volume buttons to set the minute
Press DSPL
Jan 05, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Sony "advertising" on LCD during operation
To remove the ad demo just press and hold the volume knob for a few seconds until the secondary menu appears.
Press the knob repeatedly to get to the "DEMO" item. Turn the knob to change from ON to OFF.
Press and hold the knob for a few seconds to exit the menus.
Jan 03, 2009 | Sony CDX-GT520 FM / AM Receiver
Clock set
try turning the radio off and hold down one the buttons until it blinks then adjust
Dec 29, 2008 | Sony CDX-R3000 CD Player
Need to fix the time
I have the the sony cdx gt 400 and the manual is of no help but I figured it out. You have two options...option 1 is wait until 1 o'clock and hit the small reset button on the radio behind your detachable face, or option 2 is a even better option. Press and hold the volume button in and options will appear...then by tapping the volume button you will cycle through the various options until you find "clock adjust" then press the small "display" button below the volume knob and also right next to the "source" button...the hour will flash turn the volume knob to desired hour then tap the volume knob or display button and the minutes will flash then turn the volume knob to the desired minutes, and you are done...hopefully this helps
Nov 14, 2008 | Sony CDX-GT400 CD Player
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
Sony CDX-C480 radio
I need the wireing dig for a sony cdx c480
Oct 21, 2007 | Sony CDX-C480 CD Changer
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Sony CDX-M50IP Logo
81 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
