Question about Toshiba 57H81 57" Rear Projection Television
Toshiba dynamic bomba sound system german nicam fastext old tv, in sound menu graph.equal bar, how to set that bar? someone changed that settings. sound is breaking. please help us
cinco312
  • 8 Answers
SOURCE: toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Posted on Jul 04, 2008
  • 133 Answers
SOURCE: Tuning Probleme for an 90's Nicam Toshiba T.V.
after you hook it up to the input, you have to look on the front at the buttons, there should be an input button, hit that untill you get the picture
Posted on Jan 09, 2009
  • 21 Answers
SOURCE: Toshiba VCR auto clock does not work, not way to set it. Please answer right away
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Posted on Mar 04, 2009
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Posted on Mar 19, 2009
  • 700 Answers
SOURCE: Toshiba TV Red Color turns black and regains after a long time
If this is a crt type, it could be a loose connection. Check its RGB board usually located at the backend of the crt tube. Dust, cobweb, carbon built up might be the one causing it.
Posted on Apr 18, 2009
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
Sound output to a sound bar
Most TVs have a menu setting that says internal or external speakers.Here are the instructions for yours.
Turning off the built-in speakers Use this feature to turn the TV speakers off when you connect an
audio system (see "Connecting an audio system" on page 11).
To turn off the built-in speakers:
1. Press MENU, then press x or • until AUDIO menu appears.
2. Press y or z to highlight SPEAKERS.
3. Press x or • to highlight OFF.
Feb 16, 2014 | Toshiba 36HF71 36" TV
Set tv pcm output
is it flipping back to Auto setting without you turn off the tv or unplug it ?
http://www.tvrepair.localdomain.me/
Jan 07, 2014 | Toshiba Televison & Video
Bpl nicam fqr21 digital sound tv giving hissing sound
Check the sound system settings. If it has been set to other system, like PAL/NTSC, this kind of fault can occur. Go to its audio settings, and check whether the system settings have changed.
google.com/+GopakumarGopalan
Dec 01, 2013 | Televison & Video
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
Apr 21, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I lost the manual for the code for JVC A2/NICAM FASTEXT. i know how to set it up, but the labels are erased so i do not know which one is the tv set up.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
Max volume all the time and different menu
Have you tried taking the remote out of the room,or removing the batteries?Sticky remote keys can create havoc.I would do that first.
May 16, 2009 | Televison & Video
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Toshiba 57H81 57" Rear Projection Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
