Question about Kenmore Oasis HE 27082 Top Load Washer
What does oL mean when the load is over? We just moved into a place with the washer and the clothes are soaking wet after the load is over? It's the kenmore elite.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
Washing Machine Won't Spin Dry Clothes
You may be overloading the machine. Just because you got them all in there and wet, doesn't mean there was enough room for them to get a good washing. Cut back on size of the load (make sure you have large load selected) and see if that doesn't help you.
Jan 22, 2014 | Kenmore 44932 Front Load Washer
Washer stops and shows oL over load
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
Nov 01, 2012 | Whirlpool Washing Machines
There is an OL error code on my Kenmore Elite Oasis HE washing machine. It seems as if the washer isn't going through its final spin cycle or something. My clothes are very wet and I've been having to...
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The clothes are coming out soaking wet.
just cause pump moves doesnt mean its working
Jun 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer will not drain nor spin. Did have a OL IN THE INDICATION WINDOW WHEN PROBLEM FIRST OCCURRED
The OL means that the load was overloaded and shut itself off due to weight.
Dec 25, 2007 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
