Question about Radio Shack TRC-447 CB Radio
I have a trc447cb radio, it kept blowing fuses, please help thanks...
  • 38 Answers
Could be you are using to small of a rated fuse. I use a 5amp fuse in my radio but it powers a 25 watt swing. Take it to a tec!!! PLAIN AND SIMPLE! If not, you will blow it up!
"wildcat" in Laurelville 0hio
35 years of serving the cb world!
Posted on Dec 30, 2010
    Guru:
  • 773 Answers
This radio has been hooked up backwards. CB radios cannot be hooked up backwards or it will destroy it. However this is hope.
Because they can be damaged this way, there are polarity protection diodes in the radio that will blow if the radio is hooked up backwards, before it can hurt anything in the radio.
They are usually N1004 diodes. Is a big black diode that has a white stripe. And if it is blown, it will most likely be Black and burnt.
Open the radio, and look near the power section of the radio. It will be in the back near where the power cord plugs into it.
Look for a burnt black diode. That is the protection diode.
Get an N1004 or better from radio shack, and remove the burnt one, and put the new one in, making sure to put it in with the white strip on the same side as the original.
Once you have finished. Make sure the polarity is correct. Then hook up the radio, and turn it on. Should work fine.
If you want to validate that it is the correct diode, if you pull on leg out of the board, and turn on the radio, it will turn on. When the diode blows, it prevent the power from getting to the board, if you take it out, it will let it through. CAUTION. The radio will work again if you just remove the burn diode without replacing it. But if you hook it backwards again, it will be toast, and as good a door stop.
Posted on Sep 08, 2010
1985 Cutlass Supreme Brougham...clock and radio fuse keeps blowing not long after being replaced.Thanks in advance for your help.
I would suspect that either the radio or the clock has become defective. I suggest unplugging the radio first and see if the symptoms change. If the fuse blows then unplug the clock and see if the symptoms change, does the fuse still blow? Hopefully you are able to narrow your search down to one of those two devices but if not then unfortunately, the 12volt wire, traveling from the fuse to the two parts, has shorted to ground. I hope this helps you. Please let me know how the repair is going, good luck.
Mar 17, 2014 | 1985 Oldsmobile Cutlass Supreme
Radio fuse keeps blowing on 99 ford escort zx2
I would say there is a short somewhere. You can get a resetable fuse.
May 31, 2017 | 1999 Ford Escort
Car radio wasn't working and the fuse was also connected with the car starting, but now all it does is blow the fuse. What do you think? Thanks for any help
have you pulled the radio out at all maybe a loose wire somewhere or try a higher amp fuse sometimes if your radio runs of the interior light and cigarette lighter higher amp fuse helps either that or a loose earth cable
Jan 04, 2012 | 2002 Dodge Stratus
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
Starter fuse keeps blowing
Sounds like a short in the system. you will need to inspect the wiring and posably, bench test the starter. Check the cables to the battery. Make sure the wires and the battery are in good shape.
May 13, 2009 | 1997 Dodge Neon
Power outage
this radio takes a 7 amp fuse in the fuse holder if it blows the fuse the most likely the radio has blown the protection diode at the power plug on the positive side this usually happens when the radio is hooked up backwards.
Feb 22, 2009 | Connex 3300 240-Channels Base CB Radio
Radio on "Safe" lock
you can try to get the serial number off the radio and call the dealership up for the code
Sep 21, 2008 | 1996 Volkswagen Jetta
95 Geo Tracker Dash Lights out?
replace the blow fuse
above left knee, fuse panel there.
1 is blown.
your amp was shorted, it blew and took out what oem wiring they hacked into .
bad installation.
Sep 09, 2008 | 1995 Geo Tracker
Gen lee blowing fuses when keying
What size fuse are you using? If you have a different power cord than that which came with the radio, such as one from a regular cb radio like a cobra 29, it will only have a 2.5a to 3a fuse, which will blow everytime you key up, since it is pulling to many amps. You need to have at least a 7.5a to 10a fuse. I use 7.5 amp fuses, because I have a 100 count box, and have no problems. The Stryker radio I have in front of me has a 10a fuse in its power cord from the factory, though the cord on my bench only has a 7.5a and has not blown.
If your radio still blows fuses after this, please let me know. You can message me here or email me at rollincbmods@yahoo.com.
Dean Pitts
Rollin CBs
Aug 29, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Shack TRC-447 CB Radio Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
