Question about Panasonic FV-08VQL4 Fan
I have a 3 year old Panasonic Whisperlite FV-08VQL4 ceiling fan for the bathroom, with two CFL bulbs (18W each). One of the two bulb locations is bad -- it won't turn on, regardless of replacing the bulb with new ones. The last bulb that worked gradually started to dim and turn on intermittently before it went completely out. The bulb socket looks fine. Is there a replaceable electronic part ahead of the socket that can remedy this problem?
  • 377 Answers
Sounds like a loose wire inside the unit. But, I would try this. With the power off, both switch and circuit breaker, try and bend the center contact for the light bulb out; pull it out away from the back of the socket. This may be the bad contact. The center contact on the bulb touches this in order to get power up into the bulb. Using a small screw driver, try and scrape the surface of this contact to clean it a bit. DO ALL OF THIS WITH THE POWER OFF!!!
Hope this helps.
Posted on Sep 06, 2010
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
What type of light bulb do I need for a minkaAire ceiling fan. It is about 7 years old
It all depends on which light kit was installed on your fan. As you described the fixture as requiring a "light bulb" meaning a singular bulb, Minka Aire usually uses several different types.
The most common is either a 40-watt or 60-watt Candelabra Bulbs.
(The designation "Candelabra" refers to its screw base. You can buy these in clear or frosted, torpedo or globe with a straight tip or curved. Etc.
Here's an example of a torpedo globe:
Sunlite 60 Watt Torpedo Tip Chandelier Candelabra Base Frost 48 Pack
And here's an example of a Candelabra globe:
Sunlite 60 Watt G16 5 Globe Candelabra Base Clear 48 Pack
Some of their fixtures use a 50-watt Mini-Can Xenon Bulb.
Satco S1914 50W MINI CAN FROSTED 120V
And other use a 3w CFL Medium Base Bulb.
3W CFL Deco 2700K Medium Base
When installing a CFL, Halogen or Xenon bulb, I recommend cleaning the glass with an alcohol wipe to remove any oil from fingerprints. Due to the very high temperatures these lamps operate at, the oil from your fingers will cause a hot-spot on the glass and can shorten the life of the bulb dramatically.
If none of the references I offered match the bulb in your actual fixture, you might be able to more closely match the fixture from one on the following page. The recommended bulb for each fixture is listed in the description of the fixture.
https://www.ceilingfan.com/Minka-Aire-Fan-Lights-s/2082.htm
And as always, NEVER over-lamp a fixture with a bulb rated at a higher wattage than what's shown on the base of the fixture. That is, never use a 60-watt bulb in a fixture rated at 40-watts. The additional heat of the bulb may harden the insulation of the wiring in the fixture creating, causing the insulation to fail and create a fire hazard. Also for fixtures located tight to the ceiling, higher temperatures can dry out the gypsum ceiling material, causing it to crack and deteriorate.
Feb 09, 2018 | Dryers
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Can a normal two part wall switch run all three parts of a panasonic whisperlite fan/light/night light combo
Was it wired up there before with the 2 switches? One for the fan and the other for the light? You will have to take the plug out of the fan and cut the ends and wire nut them to their wire on the switch. Otherwise it be on when the switch is on. Or,,,, Find the right wire inside there and make sure it is separated from the light and hook it up that way, then it can stay plugged into the fan unit. Check it out, hope this helps.
Oct 16, 2010 | Panasonic WhisperLite Bathroom Fan with...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Replacement bulb for Panasonic FV-11VQL4 does not fit
YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
Mar 12, 2017 | Panasonic Kitchen Appliances - Others
CFL bulbs won't work in ceiling fan?
they should all work. The only problem might be if they are connected via dimmer. Dimmers and CFL does not work together.
Mar 08, 2009 | IBM ThinkPad R50e Notebook
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Panasonic FV-08VQL4 Fan Logo
393 people viewed this question
Top Panasonic Dryers Experts
Craig Butler
Craig Butler
michael vanier
Are you a Panasonic Dryer Expert? Answer questions, earn points and help others
