Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
No power Hi I put a load in my machine and went to bed. When i woke it had stopped mid cycle, the water was still in the drum. We had to remove the water manually and the machine seems to have no power. We have changed the fuse in the plug but it still dosn't work. Sheridan
  • Anonymous May 20, 2008
    Swich is out of adjustment I need diagram of how to move the swich up
  • 975 Answers
CHECK the sensor switch under the top of washer where the door closes , there are 2 types of switches MAGNETIC and LATCH HOOK in the main door, AJ
Posted on May 12, 2008
Samsung wf317aag stopped mid cycle now machine has no power
First, are you sure there is power to the unit? Check the breakers and post back.
Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
Stopped in mid cycle.
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint washer is stopping mid cycle if i dont pump the water out it floods it will only work on thr h cycle
I WOULD HAVE THE PRESSURE SWITCH CHANGED OR CHECK THE SMALL TUBE GOING FROM THE PRESSURE SWITCH TO THE DRUM AS IT MAY BE CHOKE WITH WASHING POWER AT THE DRUM
Jul 15, 2008 | Hotpoint Aquarius WD63 Front Load...
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
2nd Bosch washing machine same problem
Since you faced the same problems with two new machine's, it sound like a manufacturer problem and you should ask for another new washer or to get your money back !!!! Good luck !!!
Aug 18, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
