Amp keeps shutting down - Audio Players & Recorders
  • 4 more comments
  • freya39200 May 12, 2008
    I know this thing is switchng into protection mode but dont know how to solve the problem
    nope is shut down with all speakers unhooked
    this is an onkyo ht-530 7-1 surround sound. The thing keeps going to standby but will finally switch on if I keep cycling switch
    Is an onkyo 530. switches into standby whenever I try to power it up
    have alredy done this keeps doing it I just dont know how to fix the problem
    have an onkyo ht 530 amp that switches into standby when I power it up. It will eventually come on if I switch it on and off a few times
  • 13,433 Answers
Some components inside the amp are failing and need to be replaced. Contact a professional service center to get it repaired.
Posted on May 12, 2008
  • 975 Answers
Lets try this , disconnect all speakers from the amp and turn it on , if it still shutting down , then you need to check , the voltage regulator IC , check the output ICs , the could be shorted , hope this helpful AJ
  • ALBERT GARCIA
    ALBERT GARCIA May 12, 2008
    then the UNIT needs to be serviced , I suggest to take the amp to an authorized ONKYO dealer repair shop. AJ
    Genius:
  • 1,665 Answers
Look if overheated.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 12, 2008
    It's power supply may me faulty.If you are not familiar whith electronic repairs better take it to an authorized service station to checkit.
    Otherwise remove cover and inspect all components at power supply board area. Pay attention at electrolytic capacitors over 100 V and if you can replace them with new of same value .
  • 3,037 Answers
What is the make and model of the amp in question?
A shorted speaker may be causing this. Check them out and get back to me. thanks
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    1. Disconnect everything (from the back of the receiver) including the
    power cord. Let it remain disconnected for at least 30 minutes. This
    is what we call a hard reset. It will recover any software corruptions.
    2. Then plug in the power cord and connection only one speaker. They try powering it up again.
    3. If it powers up, now, add one speaker at at time. Turn power off
    while you are connecting the speaker wires. (If you accidently short
    the wires together while the set is ON it can do damage).
    4. If the reciever did NOT come on after the reset you will need
    service. It probably has an activated protection circuit that has
    turned the set OFF. This is most often the result of shorted down
    output transistors - but can be from other causes as well. The most
    often causes for shorted output transistors is playing it too loud for
    a long period of time or shorted conditions in the speaker wiring.
    5. If the receiver has a blown audio power amp you will need a
    technician to repair it; you should not attempt it by yourself. At
    least not on an Onkyo.
    6. To replace a set of outputs on one amplifier will cost you around $50 to $100 depending on what has failed.
    Let me know if you need further help.
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    were you able to ever get this fixed?
    President:
  • 2,712 Answers
Can you give more details, please? Make and model, when its shutting down, etc..
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    Hello freya39200,
    This is the typical indication of a circuit failure in the unit. Could be a problem with the adjustable turn-off delay and a phase switch. If
    you are using the remote control to turn on the unit, be sure its
    batteries are good. If that does not help or the same thing happens
    when you use the power button on the unit, there is something certainly
    wrong. You may want to look for a shorted wire to a speaker, but that
    is about all you can do.
    It is probably worth sending in to
    Onkyo for repairs or going to one of their service centers. I suggest
    that you contact Onkyo (www.onkyousa.com) and ask them for assistance.
    Sorry I can not suggest any more specific fix for the problem, but
    there can be any number of failures that can cause this problem. Only a
    shop and technician with the tech data can find the problem and cure it.
Keep shutting off and it has good charge
Amazon.com: Customer Discussions: New Kindle Fire HD keeps ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 8, 2012 - My 1 month old Kindle Fire HD keeps spontaneously shutting off. I have made sure I am not accidentally hitting the power button. It gives no warning, just shuts ... Kindle Fire HD 7" won't turn on ...
Jan 16, 2014
my kindle keeps shutting off ...
Sep 21, 2013
My kindle won't turn on
Sep 10, 2012
New Kindle Fire keeps shutting down
Dec 11, 2011
More results from www.amazon.com
keeps shutting off Tablets & eReaders Questions & Answers ...
www.fixya.com > Forum > Tags > keeps shutting off
Jan 18, 2016 | Tablets & eReaders
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
My sound plays for a while and then the amp goes into protection
Try a different set of speakers or if it keeps going into protection you have a channel going bad.
Jan 14, 2014 | Audio Players & Recorders
The amp & stereo in my car keep shutting down what
check your wireing to see if you have a short run your power wire from bat the red wird you have better sound as well do the same for amp
Jul 05, 2013 | Car Audio & Video
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
20 amp engine fuse for 2000 plymouth grand yoyager keeps blowing
I don't have a picture, just a diagram. In the power distribution center, I see 20A fuse 3 for the automatic shut down relay and 20A fuse 5 for the fuel pump relay. No 15A fuses in the vicinity
Sep 25, 2012 | Cars & Trucks
MY AMP TURNS TURNS ON THE PROTECTIVE MODE
The amp is being overworked and is overheating so it is shutting down to protect itself. You could try to add a fan and point it at the amp to help keep it cool. Also make sure the amp is not located where it will get heat from an exhaust pipe under the car for example. They may have external fans that you can attatch to the amp to help cool it. The constant overheating could eventually damage the amplifier.
Oct 09, 2009 | Legacy 2CH 1000W AMP Car Audio Amplifier
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Kicker ZX500.1
not getting enough air to cool off amp, if amp is in an inclosed area with restricted air flow, amp will over heat and shut down, once the amp has cooled off, it will reset.
Mar 21, 2008 | Kicker KX400.1 Car Audio Amplifier
51 people viewed this question
 Grubhead
Grubhead
