Question about Fuji FinePix F100fd Digital Camera
Protected card. How do I 'un-protect' it? - Fuji FinePix F100fd Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 05, 2010
SOURCE: Protected card message
on the side of some picture cards there is a little tab that slides back and forth. If your card hs this try sliding it the other way. These are a write protection so to speak, or a lock in a sense
Posted on Mar 31, 2009
Steve5
  • 423 Answers
SOURCE: Can't un-protect Images in My Canon Rebel XS
It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
Posted on May 30, 2009
SOURCE: how to get off protected card
"Card Protected" problem in polaroid digital cemera model 10 megapixel i1035
Posted on Sep 23, 2009
IKnow
  • 68 Answers
SOURCE: "card write protected"
There is a minuscule tab on the side of the card, towards the "handle"-end of the card. Slide this tab to unlock the card and allow write and delete once again.
Posted on Dec 30, 2009
Testimonial: "thank you, it worked!"
  • 942 Answers
SOURCE: Card protected
When the card is protected you need to remove it first. You can slide the small button at right side of the card so that it will be being protected. After you've slide the small button you can use your camera.
Posted on Jan 14, 2010
Write Protection
Most cards have a switch on the side for protection. Pull the card, switch the switch, and put it back in.
Flash drives don't have a switch, but can be protected by an administrator, and un-protected the same way.
Apr 06, 2015 | Electronics - Others
Card memory unprotect
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 11, 2014 | Kodak EasyShare V1073 Digital Camera
How do I unlock micro sd flash memory card?
I guess u using adapter & there is small little pin on the side whitch u can move to position lock or unlock
Apr 05, 2013 | SanDisk 2gb Micro Sd Trans Flash Memory...
Memory card is saying write protected is on
Hi on some SD cards if you look carefully there is a little lever on the side of the SD card moving that will un-protect it, it is a write protect tab, to stop the contents of the SD card from being altered.
Oct 12, 2011 | Cameras
When I want to take photo a message says: memory card is write protected.How can I solve this problem
Take the memory card out of your camera. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 14, 2011 | Nikon COOLPIX S200 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Show protected card on sd card Lexar series 60x
There is a little slider on the side of the card. Push it down towards the golden contacts. This will un-protect the card.
Apr 14, 2010 | Cameras
"card protected"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 09, 2010 | Vivitar ViviCam 8025 Digital Camera
SD PROTECTED keeps on screen. Can't use an SD card. How do I take the SD protection off ? Thanks, Bill
just check your sd card lock key... there is a small swith on the left side of moemory card; if if it is in down position, it's protected. so turn it to un protected mode. I hope this helps...
Oct 31, 2008 | Cameras
Fuji FinePix F100fd Digital Camera Logo
60 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
