My Tv wont turn on Stanby mode led is off... It seems to be some power protection issue, is there anyway to restart mytc32lx58x LcdTv from panasonic_???????
  • 11,361 Answers
Unplug it for about an hour to let it reset itself, if it still does not work, then you will have to open it up and troubleshoot it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 05, 2010
I have a Panasonic tv model TC-55AS680U that turns off then the light blinks with a sequence of 1 blink pause 1 blink pause ETC.. does that tell me what component is bad
1 blink of the standby/power LED indicates a supply issue, and the set is in "protect mode". Suggestion: check for broken or loose connections (including those to the LCD panel) and P-board.
~ or ~
you can always refer to the service manual (which you can get a free copy of) for this model and chassis series.
Elektrotanya for electronics experts
The manual may be able to guide you in locating the problem and allow you to do your own troubleshooting.
P-Board = Power Supply/LED Driver - a good place to start.
Dec 20, 2017 | Panasonic Televison & Video
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
I have 3 flashing red lights when I try to power up my TV.
Over Voltage Protection . this is the cause for 3 blinks you see by its stanby/power LED.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 12, 2012 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Tv wont turn on
This is on protection mode due to errors inside the TV. Turn off TV manually, switch off power and remove plug, and retry after 48 hours.
Jul 29, 2012 | Sherwood LTA26T04 LCD TV
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Wont come out of stanby mode ??
The trouble your describing tells me that theres a short in the output circuit of this unit. Unless you know how to troubleshoot solid state electronics, Please take to a pro to have it serviced , as there are no user serviceable parts inside this unit. Good Luck
Jul 24, 2006 | Panasonic SA-XR50S 6.1 Channels Receiver
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
