Question about Whirlpool Dryers
Dryer not drying after 2,3 sometimes 4 cycles. seems to heat ok just not sure that air is circulating out
  • 560 Answers
I'm sure I don't have to tell you that you must clean the lint screen before each use . Assuming I'm right in that you already know that, Look behind your dryer from the top and see if the exhaust line is kinked or has too many sharp bends in it and repair as necessary . If OK , then I would seriously consider pulling that dryer away from the wall just far enough to access the exhaust hose itself and disconnect the hose from the dryer. Then , I would do whatever makes sense either by looking through the hose (if it's not too long ) to be sure it is clear . If the hose is real long, I would disconnect it at both ends and inspect and clean as necessary . Also , some vents have a filter at the very end of the exhaust hose were actually goes outside of the home . It can get plugged up to . Good luck .
Posted on Sep 05, 2010
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
I have a frigidaire dryer gler642as3 model it ran for two hours and didn't stop also when you open the door during the cycle it shuts the drum off but the dryer gets very hot you can't touch it what can it...
Well the timer could be defective. But believe it or not a clogged dryer vent can do some of the same things. Without air flow, the heater will heat, then when it doesn't circulate and and dry clothes, it gets hot and the hi temp overload near heater should turn it off, then when it cools it will start the same cycle over. Make sure you have good air flow coming out of the vent outside. If in doubt disconnect hose from dryer. Make sure to remove any lint. Put a panty hose leg over the hose and try the dryer. If it heats ok now, then you know your vent is clogged (panty hose will keep lint from spraying allover your laundry room)
Oct 28, 2010 | Frigidaire Timer Knob
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
I have a magtag gas dryer with that heat sensor cycle. when we set dial control there it does not move. It just runs ands runs. Clothes tumble for hours before their dry. Yet if I set dial control to timed...
Hi Joy Ann,
The automatic cycle of your dryer depends on air circulating in, through and out of your dryer efficiently. If air isn't circulating properly, your timer will stall and run forever.
Timed Dry, on the other hand is independent. The timer only does what it's told to do... count down time.
So, yes. You do have a blockage in the vent to outside. When you said the "Vents are clean", I presume you mean the lint filter. That's good. It's always good to keep that clear. What I'm talking about is the four inch vent tube from the dryer to the wall. How close is the back of the dryer to the wall? If it's less than 4", the vent is crushed. Take a flashlight and look behind the dryer without moving it. See that flex hose back there connecting the dryer to the wall? If it is pinched, so is your air flow. Either pull the dryer out about 8" from the wall, or shorten the hose.
If all of that checks out OK, though.. (your flex line to the wall isn't pinched) that means that the vent in the wall is blocked somewhere. Trust me... I've seen all kinds of things block vents to the outside. Bird nests mainly, squirrel's, reptiles, rodents... they all love to build nests in the warm place <--that would be your dryer exhaust.
Recommendation: pull the dryer out at LEAST 8" from the wall and see if that helps. If not, your Home's internal dryer vent should be professionally cleaned (should be done once a year for 2 story Homes).
Bottom line is this... if your dryer is heating, it's trying to do its' job. The only reason it can't is because air isn't circulating properly.
Look into it, Joy Ann... Dryer fires are serious and they are caused by blocked ventilation.
Hope this helps,
SG
Mar 25, 2009 | Maytag Dryers
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
