Question about Vestax Vci 100 Midi Controller
My USB port enter part came apart from the mother board.
  • Vestax Master
  • 5,603 Answers
If it is the connector, resolder the connector to the board, carefully...
If the connector is damaged, you can get new ones from several sources, including Digikey.com and Mouser.com.
Also consider finding a connector to salvage from PC recycling outfits.
Posted on Sep 05, 2010
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
M-Audio MIDI Keyboard Controller's Loose USB Port
Open up and solder in a new Type-B USB socket. Get spare from any electronics parts supplier - it is a generic part. Just 4 solder points on PCB board.
Jul 15, 2014 | M-Audio Axiom 25 2nd Gen 25-Key USB MIDI...
How do I fix my Loose USB port on a midi keyboard?
If the port is still intact then it might just need to be resoldered. USB ports however to get strained and basically fall apart. Purchase another and solder it to the board. If you are not confident about doing this take it to your local Yamaha service centre.
HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
If using link below please suply model number so correct part can be ordered. HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
Jul 01, 2014 | Yamaha Portable Keyboard with 61...
Repair usb port
Be more specific. And if you do not know how to solder, and more importantly de-solder circuit boards, do not bother. Get it fixed professionally (maybe a computer repair shop) or get another keyboard.
May 27, 2014 | Casio CTK 4000
LED Light not coming on
Did you get it used or brand new?
M-Audio is notorious for hardware related problems, mainly the USB ports. After awhile the ports wear and fail to hold the tight connection needed to keep the board fully functional. But I've seen the same problem with new boards too because of bad soldering.
If it's new then don't bother wasting time trying to figure it out. Just exchange it and save yourself the headaches. You may even want to look another board. If your partial to M-Audio then the Axiom is much better than the Oxygen. Either way, take advantage of the ability to exchange while you can, cause once that's over M-Audio will give you the finger.
Jun 23, 2017 | M-Audio Oxygen 49 USB Midi Controller
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
I need my usb port replaced on my vestax vci-300. Can you help?
The electronics of a USB port is fairly robust. Why do you think the USB port needs replacing? Or do you just mean the connector... Even those are fairly robust and if they wiggle, they may just need to be resoldered to the circuit board.
Sep 05, 2010 | Vestax Vci 100 Midi Controller
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Vestax Vci 100 Midi Controller Logo
126 people viewed this question
Top Vestax Music Experts
Michial Gueffroy
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Vestax Music Expert? Answer questions, earn points and help others
