Question about Frigidaire GLER642A Electric Dryer
Frigidaire GLer642As3 My dryer wont heat called repairman whom said there was airflow restriction I cleaned out all the lint from the entire components. How do i remove the drum so I can remove the heating coil to be replaced?
    Sergeant:
  • 291 Answers
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
Posted on Nov 23, 2008
Clean filter light wont go out
Your are getting the clean lint screen message because the computer on the control board is sensing poor airflow so it thinks the lint filter needs to be cleaned. What else you would need to check is for lint build up in the blower housing below the lint screen or the venting from the back of the dryer for blockage from the back of the dryer all the way to where it exits to the outdoors for a possible birds nest or some other thing restricting airflow.
GENE
Sep 23, 2011 | Dryers
My dryer is taking way to much time to dry a basic load
The problem is either a blocked lint filter or a restricted vent system if the dryer heats up normally or a faulty cycling thermostat if the dryer heats up erratically. Check and make sure the lint filter is clear. You may need to have a contractor have the vent system checked and cleaned as it is necessary to clean them at least once year or every six months if 4 to 5 loads are done everyday. Restricted vent system impedes the airflow and therefore the disposing of the steam it carries. This consequently results in the longer drying time.
Replace the cycling thermostat if the dryer is heating up erratically or does not heat up sufficiently.
Aug 21, 2011 | Kenmore Dryers
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Why is my maytag dryer running for a long time but not getting my clothes dry, and the vent pipe its clean?
I note the vent is clean.... Now start checking for heat from that vent with the dryer on. You did not mention the model number so we at FixYa do not know if this is a gas or electric dryer. If it is electric cycle the circuit breaker to off (PUSH hard to OFF) then back on. There is a chance that only 1 breaker is connected. It would run and not heat.
Also the airflow out the back of the dryer should gently push a relaxed hand / wrist away from the vent outlet. If it does not do this you have an airflow problem. Look inside the dryer vent outlet for any signs of lint build up. You can have a clean vent but a blocked dryer vent inside the dryer. Go outside the house and check the thru the wall vent hood and flapper for lint buildup. This is a VERY common airflow restriction point. check BOTH sides of the metal flapper for lint. Lastly if after all of this you still have airflow problems the blower wheel hub can be broken or lint on the blower wheel.
Pull the lint filter and wash the filter with vinegar and water then soap and water. Fabric sheet particulate can cause restricted airflow. Also take a flashlight and look hard around the lint filter area for lint build up. Use a folded metal coat hanger to assist in lint removal along with a vacuum and crevice tool.
If you do not have heat... at all... after all of this; please respond with a model number so we can sort out where to go next in troubleshooting.
Thanks for choosing FiXya.
Kelly
Sep 08, 2010 | Maytag Dryers
My fridgidaire dryer model FDR336RDS2 seems to run too hot
Over heating in a dryer is almost always due to an air flow problem. Typically it is in the venting.
- Check the vent from the dryer to the wall by removing it and cleaning out, make sure there are no kinks or tears in it.
- Run the dryer once it is connected and feel outside to see if you are getting the same airflow outside as you can at the outlet of the dryer, if the air flow feels weaker outside your vent is restricted and you need to have it cleaned.
- If these are ok check your lint filter, softener residue can plug up the screen so air has trouble flowing trough it, you can wash it out with a brush and hot water
- With the lint screen out take a flashlight and look down the chute, if you see lint in there take a brush and vacuum and clean good
Apr 22, 2010 | Frigidaire GLER341A Electric Dryer
My dryer check lint screen light continues to blink and the dryer wont work even after cleaning lint screen
Airflow through the dryer vent is restricted. Blow through the filter opening with a reversed vaccum cleaned. Set it BLOW instead of **** usually by putting the hose on the exhaust end.
Dec 14, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
E68 But big whooping deal. I don't want to call a
Try to vacuum it out or use a small brush. Run water on screen sometimes they look clean and are not.
Jun 10, 2009 | Frigidaire Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Auto dry not working
If there is a dryness sensor, it will be just inside the door, on the bottom right. You can clean the sensor by rubbing the metal bars with a scrubbing pad. This will remove any wax buildup from fabric softeners.
Possible reasons your clothes may still come out wet:
1. The dryer isn't tumbling the clothes.
2. The dryer isn't heating.
3. The airflow is restricted.
From your description, the third seems most likely. If your machine is the one pictured above, inside the dryer door is a plastic grate over the lint screen. Remove the lint screen. Remove the two screws on this grate (Phillips.) Use a vacuum cleaner with a crevice tool to get out as much lint as possible. Be careful to not shove any lint or debris further down into the blower wheel.
Lint can also clog up in the vent pipe. This pipe should be cleaned or replaced anually. Also, check the exhaust vent on the side of the house.
Mar 07, 2008 | Frigidaire GLGR341AS Gas Dryer
Frigidaire GLER642A Electric Dryer Logo
825 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
