Question about Canon MultiPASS MP700 All-In-One InkJet Printer
Every thing works exept wont put ink on paper
    Problem Solver:
  • 13 Answers
Okay, Craig, have you attempted to print a test page from your printer? If you have, and it didn't work, it might be your ink. I used to work for Staples, and sometimes the ink was old and dried out. Also, refurbished ink cartridges frequently do not work as well as originals. How long has it been since you have not been able to print?
Barbara-Ann
Posted on Sep 05, 2010
UV PRINTER No brand...direct from China. Everything seems in working condition, all inks coming out well, UV light working well, belt good to go,practiced on a piece of wood to adjust colors.
Try putting paper in it, maybe paper jam is being confused with no paper at all. Something else besides paper could be jamming, or something could be wrong with the thing that feeds the paper to the ink.
Mar 21, 2016 | Office Equipment & Supplies
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
Jan 25, 2012 | HP DeskJet F380 All-In-One Printer
The black ink wont work, even though i have put in a brand new cartridge. the tri color works fine, but the black ink must have something funky going on
Try the following things:
  1. remove the cartridge make sure that you have removed any tape or guards that came with the cartridge to keep the ink from leaking
  2. try gently squeezing the cartridge. if you can get a drop to come out of the cartridge.
  3. if you cannot get a drop out, put the head of the cartridge on a piece of a dampened napkin or paper towel. You should see some black bleeding out of the head. Sometimes, it can take awhile for the ink to loosen up.
  4. reinstall the cartridge and run the head cleaning program for your printer if you have one
May 27, 2010 | Canon PIXMA iP90 Mobile Printer
Headlight wont work exept on passing
Did you try measuring voltage to Headlight switch? If that works fine check it at headlight connection.I suspect corrosion.
Feb 21, 2010 | 2006 Yamaha Ybr 125
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
My printer thinks it is out of paper when it
please try to set it to manual feed
with manual paper feed it wont search for a paper and wont give an error
Thanx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Epson Stylus Color 777i InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Dispalays Reads paper jam and wont disappear
Unplug the power cord then put it back up. This restarts the printer again in case the on/off button does not work to turn the printer off. Then check if there's a paper jam. To do this open the scanner lid and also the glass lid, just the way you access the inks when replacing them. Check to see if there's any paper stuck underneath the inks by the printer rollers along the paper path.
Apr 06, 2009 | Lexmark X4650 InkJet Printer
Canon MultiPASS MP700 All-In-One InkJet Printer Logo
old marine
old marine
