Question about Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range
Locked oven door
I have a whirlpool gas range SF387LEGW7, my wife accidentally hit the clean button so she hit cancel. The stove made a few clicking noises by the oven door. She broiled some food then the next day the oven door was locked and will not open. Holding the cancel button gives a error message of E1 F5 I tried to run the clean cycle but nothing happens. On the bake cycle the oven will heat up but the door will not open I accidentally hit the clean button on the oven and opened the door at the same time. The locking mechanism engaged with the door open, and now the oven door won't shut and the oven will not work. All I get is a "dr" on the display for door open. I have tried the unplug. No go. Help! What can be done besides calling for service? slaur
  • jdriggers10 Nov 10, 2008
    I accidently hit the off/cancel button on my control panel and it locked the door. Now, I cannot get it unlocked. I tried unplugging it. I tried pushing the cancel button. I tried holding the cancel button and pulling the door at the same time. I tried the clean button but nothing has worked. I cannot open the oven!!
  • 258 Answers
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
Posted on Jan 18, 2009
I accidentally pushed the lock button on my stove and can't get it to unlock.
You should be able to push cancel/off and the door should open. If the oven started the clean cycle it may not open till it has reached a certain low tempature, where the door could be opened without the intense heat of the clean cycle burning you
I hope this has helped you,
Gene
Aug 05, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Oven Door is locked
Suggestion from => http://www.fixya.com/support/t135369-oven_door_unlock
The first step I would recommend you to do is to turn the circuitbreaker on, then set up the oven clock. Start the self clean for anyamount of time, wait about 30 seconds and push the cancel button. Mostof the time it helps to eliminate the problem.
I've read other places that turning the fan off will unlock the oven.
Dec 31, 2008 | Maytag MGR5751AD Gas Kitchen Range
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
"Locked Door" flashes after interrupting self clean...
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control: Motorized Switch 1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel. 2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed. 3. While you hold the door jamb switch in this position, complete the following steps. 4. Press the Clean pad, wait 10 seconds. 5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it. 6. Wait 10 seconds for the display to clear. 7. The door should unlock and there should not be a need for service. Manual Switch 1. Press the Clean pad. 2. Close the door. 3. Slide the latch to lock the door. 4. Hit the cancel button immediately. 5. Unlock the door.
Aug 25, 2007 | GE JBP60 Electric Kitchen Range
Locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Oct 31, 2006 | Whirlpool RF378 Electric Kitchen Range
Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range Logo
357 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
