Question about Maytag MSD2656G Side by Side Refrigerator
May tag m2260i side by side
I bought my fridge maytag m2260i it is working perfect but i always get crush ice and the door for the ice is not opening
help please
  • 1 more comment
  • chinchinalsa May 17, 2008
    hi i found these no. at the back of the fridge
    REEFIGERANT 134A
    GC2228EEDW
    that all the no. i found nothing else
    thank you for your help
  • chinchinalsa May 22, 2008
    hello
    i try to find the no. in side the fridge but there isnot any one i dont know maybe lost or somthing
    anmy way the metal arm inside the frees is working good and the ice inthe ice bucket is cubes but the problem is when i select from outside the frees cube ar crush ice it is all the time crush the ice fro me and keep it the frees door couse as i said the flapper door in the ice dispensor is not opining
    thank you again for your help
  • chinchinalsa Jun 06, 2008
    hello again thanl you for your replay the serial no. is 16093651YU
    hope this will help
If you pull out the middle drawer and look to the left you will find the model number.
Posted on Jun 03, 2008
  • 45 Answers
That is not a good model number the model number is in the refrig section post serial also they are together.
Posted on May 16, 2008
  • charlie hawkins
    charlie hawkins May 22, 2008
    hello again, the model and serial tag for the unit is in the refrig section. open the refrig door look up and left or right you should see the model serial tag close to where the side meets the top of the inside of frig. if this the model that i think it is, there is a metal rod that goes along the right side of the ice bucket that is moved by a lever in the back of the freezer section, this makes the crushed or cubed option of the ice dispensor work, alot of times the ice bucket does not get put in correct and that causes the metal arm not to work like it should, the flapper door in the ice dispensor is open from a solinoid ,but if you are only gettting crushed ice alot of times the crushed ice freezes in the ice chute not alowing the flapper to open , let me know more try and find that model and serial numer.
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Ice that comes from the door is always crushed
empty out all of your ice than wait for it to fill up a new tray and than it should be cubed if it doesnt change you might end up sticking with it because you will need to change the control panel behind the buttons your pressing
Jun 08, 2009 | GE Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Sep 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE TFX27PFS Always makes crushed ice.
The crushed ice sounds like the solenoid in the back of the freezer may be frozen and moving the mechanism (rod) even though you can move it by hand. Take a hair dryer and heat the area where the ice bin rod fits into in order to thaw the solenoid out. You can take the whole thing apart and put a little petrolium jelly on the shaft to keep it from freezing and sticking again if you have the tools. The door alarm may be the door out of adjustment... hold the light switch down and see if that stops the alarm, if it does you can always glue an extension piece on the switch in order to reach the door again vice adjusting the door. Some of these models were very close to being out of adjustment and a few years of wear on the hinges could do that. I've even seen someone glue an extension on the door so it would press the switch better on closing. As for the water leaking, is it continuous leak or say every 12 hours you notice a little bit of water? Continuous leak is likely a solenoid valve letting water by, small leak every 12 hours or so usually means the defrost drain line is clogged and the defrost water is not making it to the holding pan but leaking out the freezer compartment instead.
Jan 28, 2007 | GE Profile CustomStyle PSI23NGR Side by...
Maytag MSD2656G Side by Side Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
