Question about Whirlpool Washing Machines
Washer won't start lights are stuck on i believe the lid is not down but i don't see any switch modellce4332pq1 whirlpool compact
  • 560 Answers
Before you do anything else , unplug the washing machine for about five minutes , then plug it back in . By doing this , you will reset or reboot the computer inside the unit . It may just be frozen , similar to when a computer crashes or your screen locks up . If this doesn't work and doesn't take care of your problem you'll probably have to consult a qualified service technician .
Posted on Sep 05, 2010
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills with water but then will not cycle through after filling tub
I looked up yur model. It is a fine washer. Your lid switch on this model don't allow for wsh or spin if the the lid is ope. Older models would let the washer wash but not spin. This switch here won't allow for wash or spin. How it works
My page on these
Note: this washer is a newer model and I have yet to come across one. I believe your problem to be the lid switch. It has 3 wires. 2 hot ones and another one attached to the frame. Jump them 2 live wires and see if she runs. If it works get a new switch and party on!
I am TheMobilian.
Let me know what ya find out, I am here to help.
Jul 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
The tub fills with water for the load size selected, but then the agitator will not work on my Whirlpool. Tried to move agitator by hand, but it is locked up tight. I have already replaced the time, and 3...
send the model number?if it's a top load washer check the lid switch,if the switch is broke it will fill and do nothing,if it's the coupling the motor will run but nothing will move,close the lid and then open it a little and close it a few times,if you don't hear a clicking sound you have a bad lid switch,you can also open the lid,set the timer on spin and with a screw driver push down on the switch on the right side,if it spins the lid switch is bad,it has to work only if you hear it clicking when you push down on it,if it don't click it's bad.let me know what you find.also if the motor is humming you could have something stuck in the pump,pull off the frame,pop the metal clips on the pump and slide it off and start it,if the motor runs you have a bad pump or something stuck in it.
May 13, 2011 | Whirlpool Washing Machines
Whirlpool Kenmore 2.1 cu. ft. Compact Portable Top Load Washer
did u try leaving the lid pushed down? I just had the same problem and had to push down on the lid in oirder to get it to work and leave it pushed down during the entire wash, it was quite a pain
Jun 01, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
