Question about HP Computers & Internet
Hi i have this problem i dont know if its bad or not but every night i turn off my lap top and let it charge over night then this morning when i log on to my user my battery says 4% plugged in, not charging why? PS: my HP laptop is not old i just bought it last April
  • HP Master
  • 1,606 Answers
This can be a couple of things. The battery, the charger, the internal charging circuit, or the connector.
The battery is not that old but just enough that you could see problems depending on how you use or charge. If you drained it a lot or never used it on the battery this can happen. If the battery was the problem then you would see very short run times when it was fully charged. For example it may run down in say 10-15 minutes or less. The battery may still be under warranty. If you feel a hot spot on the bottom of the laptop after charging overnight this usually means the battery has a problem. The heat is from the charging circuit working pretty hard.
The adapter or charger can be bad but rather rare for it to happen. Usually they work or they don't. Again should be under warranty.
The internal charging circuitry can be having a problem. Not common at all but it happens. Again will be covered by warranty.
Last is the charging plug. This is the connector where the adapter plugs into the laptop. If the plug has been damaged or is loose it won't charge properly. The way to check this is to plug the adapter in and then gently move it around if the plug moves or doesn't feel secure then this has a problem. Usually when this happens the lights on the laptop may flash off and on as it makes proper contact. This may be covered under warranty. When it isn't they will say it is user abuse.
It may take you a bit of watching to see what the problem is. It could be a one time thing ie the connector wasn't plugged in right. It can be a bad battery. Batteries can go quickly but normally they fail fairly slowly over time. You need to check if you have warranty. All of this should be covered on a ~18 month old laptop but you may only have had a 1 year oem warranty.
If you have to pay for anything a battery is $40-$80, a power adapter about $50. The charging circuit requires a new mainboard and the plug depending on the model either requires a new mainboard as its built in or the plug is a seperate piece which can run from $5 to about $100. The battery and the plug are the most common cause for this type of problem.
Posted on Sep 05, 2010
  • 3 Answers
Battery problems are often related to the battery itself. If you're experiencing this problem, contact your mobile PC manufacturer. If you purchased the battery separately from the mobile PC, contact the battery manufacturer.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Battery has gone bad Please change the Battery. Always keep it im mind that the battery level should not go below 20%, if that happens for several times then the battery will go bad permanently.
Shiva
I cant log on my lap top through my friends router she dont know
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Feb 24, 2010 | NetGear WGR614 54Mbps Wireless Router...
Pluged aspire 4520 in at night. next morning, no lights no power. nothing
if the unit will power one with ac adapter plugged in then you have a bad battery. check to see if you dc jack on the lap top lights up when you plug in the AC. if it does not light up then your dc jack or ac adapter is bad.
Jan 27, 2010 | Acer Aspire 4520-5582 Notebook
I installed Norton 360 on my computer then later shut it down for the night. The next morning when I awoke I turned on my computer and now it won't get past the Windows XP log in page. I click to log in...
Hello. Call Acer and have their support tech talk you through the necessary fix Since your lap top is new it will be under warranty so they will help you for free. Regards, Joe
Dec 18, 2009 | Acer Aspire 5000 Notebook
Screen goes black
what do you mean by going dark?
dimming down or going off?
e-mail me djtatty@hotmail.com
Aug 12, 2009 | Computers & Internet
Lap top not turning on
i dont know anything about the number 9 lock thing, but try plugging your laptop into a power supply if you havent already, if that fails then take out the batteries and put them back in again, this worked for my friend when a similar problem happened
hope this helps
josco91
Jun 23, 2009 | Dell Latitude D430 Notebook
Leaving samsun phone on while charging
actually it hurts every battery even your lap top's
Oct 14, 2008 | Samsung SGH-D900 Cellular Phone
Alam going of when Phone turned off
ok some electronic items has a backup source some internal so alarm may just be in the sof ware manufature ..also the cell battery can still be inuse if the cell is on stanby come customer may think thecell is off so your battery could have
Aug 29, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Computers & Internet Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
