Question about Dell Inspiron B130 Notebook
I have a standard configured dell inspiron B130 laptop when i push the power on the system lights flash but the machine shuts back down, i do not believe the battery is any good so i use ac power. also is this help information free
  • Abhilash Valson Sep 05, 2010
    can u send in more details about the specs of the machine... and more details on what happens once u press the power button does it reach the splash screen, does it finish the BIOS and does it reach the OS
  • Ronald McDuffie Sep 05, 2010
    when i plug the machine in to ac current the battery light comes on, when i push the power on button the system lights will flash on and go back out, if i hold the power button down the lights will go back out almost immediatly, the machine does not seem to even start a BIOS check and it never reches the OS, the screen remains black, my niece was using it when she truned it off it started this problem the next time i tried to use it. But as I said the screen does not light up, and the lights flash and it seems to power back off immediatly after the button is released.
    Scholar:
  • 83 Answers
1.have u tried using a new charger? or atleast borrow someone's charger for the same model and try 2.how bad is ur battery. if it is ok enuf to start the system can u try that once 3. try removing the battery pack and disconnect the cable for power and press down the power ON button for 30 seconds and then replace just the charger and then start the machine keep the battery aside 4. did ur niece have to yank the cable out when she finished using the computer? maybe the joint where the connector had to go in was broken 5. was there any reason for voltage fluctuation(lightning rain etc) maybe the junction where the power reaches the motherboard was burnt 6. If all these are fine then ur voltage controllers must have blown.
4 and 5 can be rectified if u have soldering experience... 6th one needs more better tech support and most chances are when u get to a techie he would ask u to replace the mobo
Posted on Sep 06, 2010
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
CRASHED DELL INSPIRON B130
As you cannot power up I cannot see it being an AVG problem although it seems strange that it happened after you installed it.
As you needed to download an anti virus prog because you thought you had some then we will presume you were on the internet unprotected. A big mistake!!!
If you have a virus/trojan stopping your system from starting then you need to download the following on another PC and burn to disc. You must also make sure you laptop is connected to the internet or follow the instructions on the website below.
If this does not work then it is a problem with your laptop.
Here's the link full instructions and download here (at the bottom of the instructions.)
http://www.raymond.cc/blog/archives/2008/07/26/free-f-secure-rescue-cd-300-to-clean-virus-from-unbootable-windows/
May 05, 2010 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 won't wake up after closing lid
Right Click on desktop--> Properties--> ScreenSaver-->Power--> Advanced
And from there U can set the things According to u
Hope It Solved Your Problem
Good Day
Apr 13, 2009 | Computers & Internet
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
Lights flashing on my dell inspiron b130
Remove all power sources and try restarting it with just the A/C adapter connected. Does it power up then?
Dec 27, 2008 | Dell Inspiron B130 Notebook
Won't turn on. Power adapter light on - noting on the b130
If the power light is on then the laptop is getting power.  Take the battery out and if the power light is still on when you push the power button then there is something else wrong with the laptop.
Dec 11, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
