We live in Albany WA. We have a DGTEC DG-HD 5210 set top box. We have excellent reception on all available channels except ABC HD which is a good picture but no sound. Any suggestions to fix this issue? Thanks
  • gibbfamily1 Sep 05, 2010
    Thanks very much, your first option worked. The sound on all channels sounds a bit different but it will do. Thanks again
    Yes, sent a positive comment to Azraelsri, Thankyou
  • 11,800 Answers
It's a well known problem in DGTEC receivers - the AC3 / 5.1 surround sound isn't properly decoded. The 2 possible fixes for that is to either downgrade the output to 2.0 stereo or select in the settings for that channel the MPEG-1 decoding option if available. If this doesn't fix it you will have to do a firmware upgrade - or take the unit to a shop for them to do it.
Posted on Sep 05, 2010
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
Hi. I now only get audio for channels 73 (Mate), 24 (ABC 24/7 news) 44 (Channel 31). I have lost audio for all other (forty-something)channels. I have a DGTEC DH-2000A set-top box. I have tried a rescan...
Ok here's the fix, you're only recieivng audio on HD channels because you've got your audio set on automatic or dolby ac-3.
Click menu on your remote, go to a/v settings, then audio and change it to MPEG-1.
Should sort you out.
Sep 28, 2010 | Televison & Video
DGTEC top box,DG -HD8710, lost manual when moving
The main aerial goes into the box,then a flylead out of the box into the tv(if you have a vcr or dvd rec then it will go in there first then out into the tv).Then connect the box to the tv with a scart lead.
Nov 07, 2009 | Televison & Video
Cannot receive HD signal
TERK HDTVa is a good amplified indoor antenna.
Jan 04, 2009 | Samsung SIR-T160 DTV Receiver
In London, Uk. I have poor reception of channel 5. have got recently a one for all powered aerial. how do I set it up? Model sv-9140-00-002
Your reception would be much improved by using a free to air digital set top box - only about £20. If you are in east London especially near docklands channel 5 reception with a conventional aerial gives a lot of problems. sv-9140-00-002 is an interior aerial booster - I doubt whether this will improve things much. Best solution is a good outside aerial - if you live in flats is there no communal aerial available?
Mar 17, 2008 | Televison & Video
MANUAL FOR HD SET TOP BOX
Try this link. Ijust downloaded the manual from here myself.
http://www.dgtec.com.au/arbitrage/pages/134/DG2000A+UserManual.pdf
Regards
Graham
Jan 19, 2008 | Televison & Video
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
