Question about Sport & Outdoor - Others
Hyper extension JN 1360 treadmill - displays Er04 on the screen and will not work.
3 Suggested Answers
  • 5 Answers
SOURCE: my hyper extension machine jn 1360 walking machine
I believe the underside of the magnetic key (the one that stops the machine if you remove it) contains an electronic component that becomes faulty. The machine "thinks" the key is not in place even though it is. My solution was to take the console apart and bypass the faulty component (DO NOT try this unless you have a basic understanding of how NOT to be electrocuted and how NOT to cause fires, shortcircuits, and/or general mayhem). The alternative is track down an electronics repair type person to do it. BUT the
downside for me is that I've lost that instant stop function when you slip/fall/etc.
Posted on May 21, 2010
ercupa190
  • 12223 Answers
SOURCE: error code 3
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Posted on Jun 30, 2012
Hyper Extension JN 1360 Error Code 4
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 07, 2016 | Exercise & Fitness
Hyper extension treadmill model TS 1368 has a blank but lit display screen and starts straight into full speed when turned on and none of the buttons work.
First of check the connections form the main board on the motor side to console and also there inside the console for any lose contact. In both side it would be a detachable connector. Detach it and reconnect it. Be sure to remove the power cord before accessing the inside circuitry. Because treadmill have live parts,which can lead to electric shock.
if it doesn't help the you have to go for a new condole. for that you have to contact the service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 07, 2016 | Exercise & Fitness
Get an e02 error every time I press start on my hyper extension treadmill
Replace the old battery from display board
2) clean the contacts batteries+adjust the REED swithc see diagram
3) tight the ribbon cables and clean it
4) LUBE the deck belt and rollers bearing
5) Test the motor and see the control motor board see the b.diagram
Mar 05, 2013 | Exercise & Fitness
Hyperextension jn-1360 type h 6136004 error Er o2 comes up after 20 sec running and then stops
1) Adjust the speed sensor see the diagram, clean it, and tight the connector very well.
2) test the input voltage motor, if there are the motor need repair,se my personal TIPS
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block
4) Run the software caibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 20, 2012 | Bh Fitness T8 Basic Treadmill
Where to buy speed sensor for hyper extension 1360
Being a treadmill my friend,it should not be in the "Cars and Trucks"catagory,thanks
Aug 28, 2012 | Cars & Trucks
Error code 3
God bless you
Jun 29, 2012 | Exercise & Fitness
Screen won't work
Dear Sir:Adjust the reed swtich see the diagram attached, clean, and tigh the connector very well. 2) Tight the ribbon cable from key pad 3) Tight the connector from display board vs lower board 4\)Measure the voltage input for treadmill must be +- 10% tolerance 5) Reset the c. breaker 6) Test the fuse inside 7) Do not use extension cord 8) Use indepent circuit for the machine 9) Try to use stabilizer voltage 10) Run the software calibration for diagnose and troubleshooting easy.
May 03, 2012 | Proform 400 CT Treadmill - Treadmills
I have hyper exxtension treadmill its not turning on displaying error 2 whats the solution.
Hi, it means that the lower circuit board has gone & needs a new one. Just found out that these are $154 plus $15 postage from the manufacturers in Melbourne.
Jan 12, 2012 | Exercise & Fitness
My Hyper Extension 1360 model is diplaying a error 4 message
hi im wanting to know if there is anywhere that i cld buy a orange switch its to turn the readmill on and off
Nov 16, 2010 | Exercise & Fitness
My hyper extension machine jn 1360 walking machine is reading error7 on the display unit, what does that mean?
Jan 29, 2010 | Exercise & Fitness
Sport & Outdoor - Others Logo
237 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
