Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Why is my cabrio flashing Lf??? - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
4 Suggested Answers
  • 1028 Answers
SOURCE: whirlpool cabrio
check hoses and screens make sure water flow to machine is on all the way and hoses not reversed ..last resort main fill valve has bad coil on one of the valves
Posted on Apr 19, 2008
  • 132 Answers
SOURCE: Whirlpool Cabrio is flashing a LF code and all the
You may have accidentally put the machine in demo mode or one of the test modes in diagnostics. Try unplugging unit for a couple of minutes and restarting to reset board. It may be something else more serious, or difficult to find, but it cost nothing to try.....
good luck
Posted on Mar 22, 2010
livewire874
  • 618 Answers
SOURCE: Washer machine will run for
Check you water supply to make sure one or both of the lines are clear. Remove the lines fro the washer and clear screens if need be.
Posted on Oct 27, 2010
My whirlpool cabrio is reading LF and F1
Your Cabrio is continuing to fill (Long Fill) past the set limit, causing a Flooding potential.
Oct 05, 2016 | Whirlpool Washing Machines
Washer machine will run for a little while then flash lf code it is a whirlepool cabrio
Oct 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LF flashes only when I use the "sheets" function. The LF appears 2 minutes after starting the cycle.
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won't change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LF IS FLASHING ON MY WASHER. WHAT DOES LF MEAN?
Check the top spray bar, the jets are most likely clogged especially the one that push it around.
Apr 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
