Question about Xerox DOCUMATE 510 Flatbed Scanner
Xerox Documate 510 - when doc's scanned images come out black
When i use the feeder on the scanner. first page comes out great but then the rest of the documents either come out white or black. i just got this machine,help!!
5 Suggested Answers
SOURCE: my Xerox Documate 510 adds
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
  • 130 Answers
SOURCE: Xerox DocuMate 510 Scanner
www.xerox/support.com
Posted on Jun 21, 2009
  • 12 Answers
SOURCE: When I use the automatic feeder on my Xerox
Clean the scanner ! typically something has fastened on the reading unit.
Read manual for the procedure
Posted on Aug 21, 2009
mohanchennai
  • 490 Answers
SOURCE: I have a xerox documate 510 scanner I can not scan
Clean the rubber rollers with Iso Propyl Alcohol. If worn out replace them. Fan the papers so that they are not sticky. This should work.
S. Mohan
Posted on Aug 29, 2009
Xerox 510 wide format printer error code LL-12
PLEASE INFORM ME
MY XEROX 510 IS DESPLAY ERRORE CODE LL-12
Jul 18, 2014 | Xerox documate 510 - 600 X 1200 Workgroup...
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Images scan black via flatbed or auto feed
Check your software settings, Try Auto Brightness for scanning a white sheet.
S. Mohan
Nov 06, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Jul 16, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
