Question about Nikon Coolpix 2100 Digital Camera
The lens is stuck and will not retract - Nikon Coolpix 2100 Digital Camera
    President:
  • 1,194 Answers
Follow this steps in order the resolve the issue.
  • What you can try to do is spray some compressed air into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
  • Switch the camera OFF and then ON again 2-3 times.
  • Remove and recharge / replace the battery, If the error does not clear, Keep battery battery out of the camera overnight, and try again the next day.
Else your device need service (repair)
Good Luck & have a nice day.
Posted on Sep 05, 2010
Lens Error - won't retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2010 | Canon PowerShot A540 Digital Camera
The lens on my camera is stuck. I dropped it.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 16, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
Jul 25, 2008 | Kodak EasyShare M853 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Fuji A607 lens will not retract or open
Hi.
That is often caused by a lens problem. The lens mechanism gets stuck because of dirt, or because of a fault.
Follow the instructions here: Lens not retracting on digital camera.
See also: Lens Error.
Regards.
May 20, 2008 | Cameras
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
The lens is stuck
my daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Sep 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
