Question about Campbell Hausfeld 20 - Gallon Air Compressor
Is the Campbell Hausfield model # WL600701 an oilless compressor?
5 Suggested Answers
  • 1383 Answers
SOURCE: No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Posted on Dec 13, 2008
rayname
  • 70 Answers
SOURCE: wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Posted on Jan 09, 2009
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
kb8dns
  • 494 Answers
SOURCE: my campbell hausfield wl660001aj will not come on
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Posted on Feb 14, 2010
How many liters of compredssor oil to fill tha compressor tank
I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
Feb 25, 2015 | Air Tools & Compressors
Hot WL611200 air compressor
Campbell Hausfeld WL611200 Oilless Air Compressor This is an oil less compressor. Yes compressors do get quit hot. That's normal. Just keep the fins clear.
This
May 21, 2014 | Campbell Hausfeld FP2028 1 Gallon Air...
I bought a HS5180 air compressor from WW Grainger. I lost the manual, and directions to install. Can you please email them to me? Thanks Jeff
Jeff, you can go to the Campbell Hausfield website, and download all of that. You can save it as a PDF file, and just print it yourself.
Apr 08, 2010 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
Jan 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Wiering
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld 20 - Gallon  Air Compressor Logo
271 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
