Question about Craftsman 10" Table Saw
Craftman 10 inch stationary table saw model number 315.228390 we replaced the switch because the book said to but something else is wrong with it when you turn the switch on it kicks the breaker off before the blade starts turning
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 360 Answers
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 15, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
  • 10 Answers
SOURCE: I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Posted on Feb 12, 2010
FixYaSteve
  • 57 Answers
SOURCE: what kind of dado blade can I use on my craftsman
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Posted on Jun 14, 2010
Craftman table saw model number 315-218291 is it on a recall
Craftsman Table Saw Recall. Thousands of Craftsman portable table saws sold exclusively at Sears are being recalled. ... The recall involves about 46,000 Craftsman brand ten-inch table saws. There have been 11 reports of it collapsing, with nine of which causing injuries to fingers and hands.6 days ago
Craftsman Table Saw Recall ' NBC Bay Area
www.nbcbayarea.com/on-air/.../Craftsman-Table-Saw-Recall_Bay-Area-415673483.htm...
craftman table saw Google Search
Mar 14, 2017 | Saws
Question on craftman table saw S292.
Put the model number (it'll be something like "123.3321") in the Google search bar and you'll find a manual for download. Then list on Craigslist and you'll be rid of it quickly!
Oct 10, 2017 | Craftsman 10" Table Saw
I need the owners manual for a craftman table saw model # 11319063
Can't find that model number BUT I did find something close. Go to "managemyhome.com" and type in 11319 after clicking on the manuals in the header bar and it will bring up a selection of radial saws, on page 2 there is a number close to what you listed. The manual is 80 pages long if you download it complete. Let me know if you need more help
May 11, 2011 | Craftsman Saws
The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Dec 25, 2010 | Delta 36 979 10 Inch Left Tilt 1 1/2...
I need a replacement belt for my craftsman 10 inch table saw.
if you get the model number of the saw to me, i can get you the part number and source for the correct belt.
Jul 22, 2010 | Craftsman 10" Table Saw
Nov 03, 2009 | Craftsman Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Craftsman 10" Table Saw Logo
423 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
