Question about DISH Network IR Remote Control
Can not control the volume on an rca - DISH Network IR Remote Control
    Problem Solver:
  • 9 Answers
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Posted on Sep 05, 2010
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Volume control on rt2370 rca remote doesn't work.
Hi there
I would try going into VOLUME through the MENU and find volume there and set it accordingly.
good luck
Kolbrun
Mar 26, 2012 | RCA Audio Players & Recorders
WE HAVE A RCA HTS 5000 THAT WE CAN NOT FIGURE OUT HOW TO ADJUST SO THE VOLUME IS NOT ALWAYS SO LOUD BUT THAT CHANGES WHEN THE MOVIE OR SOUND CHANGES
Need more info. Are you using the volume control on the unit as your main control or the volume on the TV? I have a setup in which my sound is routed through a 5.1 Teac amp. The sound level on the amp os set and not changed. The volume control on the TV dictates the amount of sound. If the amp volume is set too high, then this will be amplified even more through the TV's sound input (the red and wite RCA cables).
If this is the case, turn down one of the folumes (the one that remains unchanged) and see what happens.
Jun 05, 2011 | RCA Audio Players & Recorders
RCA remote only controls volume.
ask a tv technician for the kind of universal remote which might best fit your tv common control...
Dec 31, 2009 | RCA Universal Remote Control
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Volume Problem
change battery first by going so you will reset the code to the remote bye taking them out if this does not fix it re program another code from rca code page thompson consumer electronics home page they are rca <<<
Jan 04, 2009 | RCA RCR450 Remote Control
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
Oct 12, 2008 | RCA 257003 Remote Control
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
DISH Network IR Remote Control Logo
298 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
