Question about Honda Measuring Tools & Sensors
The Honda 3000 portable generator was running consistently well until it sputtered , backfired and stalled. The low oil light came on. I changed the oil, installed a new plug (which is getting spark) and cleaned the carb bowl and drained gas thru the carb drain. The oil light is off but the unit won't start and occasionally backfires- especially if I give it a shot of starting fluid in the carb throat. It turns over fine but won't start. Could the low oil sensor be the problem or maybe a clogged jet? I'm frustrated.
    Top Expert:
  • Honda Master
  • 45,616 Answers
Probably the low oil sensor as they do fail or needs to be reset
was the oil level low when it stopped
discuss the problem with the service dealer
Posted on May 15, 2017
  • 17 Answers
SOURCE: Tecumseh HM80 on coleman generator. won
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Posted on Mar 01, 2009
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: brand new honda lawnmower starts and runs fine then backfires
There should be 1 or 2 screws on the carb. You will probably have to remove the air breather to get to the screw(s). I've been seeing a lot of these types of questions, new equipment not running properly. Factory settings were not set properly.
When you find the screw(s), screw in a clockwise direction until it stops; DON'T SCREW DOWN TIGHT, JUST UNTIL IT STOPS. Then unscrew counter clockwise 1 1/4 turns. Try starting.
Continue this process, 1/4 turn at a time up to 2 1/2 full turns. If you forget where you are at on the turning process, start over by screwing back down. Then pick up process where you left off.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Posted on Oct 09, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
I have fire and gas but will not start oil alert light on when crank
By fire I assume you mean spark at the plug. When turning the engine over with the key and the oil alert light comes on the spark is interrupted by grounding the system thus the engine cannot start.
First, look at the obvious things, check oil level if it is at the recommended level smell the dipstick if it has a strong smell of gas
change the oil and try to start it again. Be sure the plug is not soaked with raw fuel before you try the restart. I the problem persists you can disconnect the wire from the top of the low oil sensor.Try to start the gen. if it starts change the low oil sensor.
I hope this all makes sense to you , good luck with it.
BR
Jul 24, 2014 | Honda 3000 Watt Portable Generator
Why is spark plug breaking down on new honda generator 3000?
If the plug isn't fouled and looks all right, it could be the resistor cap on the plug wire. It could also be a warning from the CDI that it is giving up the ghost.
Jul 05, 2014 | Honda 3000 Watt Portable Generator
Speedometer not working low oil pressure light on and EPS light on
id not drive it or even run it with low oil pressure.. boom $3000 in to rat hole?
or did the engine stall. RPM goes to zero so does oil pressure.
all normal for a stall. did it stall????????
if not check fuses.
if did, diagnose stalling, ask !
Jan 19, 2014 | 2005 Honda Civic Hybrid
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
I have an em3500 honda generator which starts stalling out after 1/2 hour to an hour like it is running out of gas and then shuts off. I can restart it and it will run for 1/2 hour to hour and do the same...
Recheck for spark when it stalls. If you have lost spark I would say a heat damaged coil.
You should also drain and inspect the carb bowl. You may have low fuel flow which limits full throttle operation to 30 minutes or less. When it dies you are just refilling the bowl for the next run.
Good luck and be careful!
Aug 10, 2010 | Honda 3000 Watt Portable Generator
Honda 3000 eu no spark replace ing coil still no spark
Is there enough oil in the crankcase? Many generator ignition problems come from the oil level sensor. Either not enough oil or the sensor being bad.
Jul 21, 2010 | Honda 3000 Watt Portable Generator
Generac 6500 1988 in R.V.Southwind Two things, both only occur in the morning or when cold (I am in So Cal so not that cold). First, when starting the generator from the dash board starter button the light...
See if there is an oil pressure guage on the dash. When you start the machine it probably has a low oil pressure shutdown which shuts the engine off when you release the start button. This is an interlock. Watch the oil guage and keep the start button engaged until you see oil pressure, release the button and it will continue to run at that point. Your second issue may be a function of the choke. If you are having to choke the engine to start, you may have to play with the choke position to keep from overfueling the unit which may cause it to stall and possibly backfire as it has to much fuel to be burned on the compression stroke, and is igniting occasionally on the intake stroke. Hope this helps. Marvin
Jan 20, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Measuring Tools & Sensors Logo
60 people viewed this question
Top Honda Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Honda Measuring Tool and Sensor Expert? Answer questions, earn points and help others
