Question about Dell E173FP 17" LCD Monitor
Same problem here with my Dell lcd monitor. monitor seems to be receiving the data from computer i play with the button in front but i can only receive data for no more than a couple of second,and then it's gone. is there something wrong with the configuration of the monitor
  • 11,361 Answers
More likely to have cold solder joints, shorted out transistors in the inverter circuits, fuse.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Replacement board: http://www.lcdrepair.us
Posted on Sep 05, 2010
How do i adjust the brightness on a dell 1801fp?
Play with the arrow up and down on the monitor.
Terry
Jan 14, 2015 | Dell Ultrasharp 1801FP (Midnight Grey)...
How to get rid padlock Dell E176FP 17" LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
My monitor Dell 1703FPT will not come on and the power button does not light up either...any suggestions?
Got the same problem. Remove the front ring around the screen, to check out the actual switches. Everything seemed normal, but nothing worked... Could it be in the power supplie itself?
Mar 21, 2011 | Dell 1703FPt 17" TFT LCD Flat Panel...
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor Problem
lower right hand side are some monitor setting buttons.
They should let you configure your brightness and contrast,also sharpness.
One button may do an auto fix.
Also in your win control panel click on display, advanced. and set your resolution until your happy with the picture.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
DELL E173FP 17" LCD MONITOR
try to contact dell. Maybe the power supply inside the case is bad. Try without VGA input. It should say dell genious display
Dec 18, 2007 | Dell E173FP 17" LCD Monitor
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
527 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
