Question about Dryers
My dryer stop running and a bad burnt order coming from the inside. Now there is no power to the dyer and it will not turn on. How do I fix the dryer. I have already checked the circut breakers and they are fine.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a burning smell in my dryer. it heats up and runs but the clothes have a burnt smell
Do not switch on the dyer unless this is checked out as the fault seems related to the coil heating some insulation or foreign particles when it is switched ON.
Sometimes this can be due to wires buring after coming into contact with the heater, the insulation being burnt out.
Also if the connection leads on the heater is bad then the JOINTS might heat more and thus burn the wires or any other materials that come in touch.
An inspection / with a good obserrvation lamp is most important.You can also start by observing the leads on the heaters.
Aug 18, 2011 | Kenmore 76972 Dryer
Dryer stopped running in the middle of drying cycle. Circuit breaker was checked and reset. The light inside dryer will not turn on when door is open.
check that you have power coming to dryer...check for burnt wires going into cord area...it also could have blown your thermal fuse. its best to have a electrical tester to check componants
Jan 14, 2011 | Maytag Dryers
Will not run changed start button . still will not run. but I put power to the dyer I here like a clicking sound coming from the time which
heatman101
Jan 05, 2011 | Kenmore Dryers
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
My dryer wont stay on.
you have a bad microcomputer or as some calls it (even heat board) thats needs to be replaced / if you cant find one contact me with the complete model number from the sticker inside door area and i will see if i cant help you with one / larry
Dec 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
