Question about LG 42LC2D 42 in. LCD HDTV
Hard to turn on. light on t.v. flashes and hesitates to turn on the picture. sometimes it takes three times turning it of and on before seeing a picture
  • LG Master
  • 8,457 Answers
The power supply board have problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 05, 2010
Tv went crack while watching. Picture and sound went out & red light flashing.Waited a min,turned off and back ok with picture and sound returning concerned if we should continue using or not?
As long as you can see and here the picture with no problems you should be fine. The tv's put it heat which make things expand and contract. Sometimes things creek and crack. I've had two tv's that do that. Don't hesitate to keep a fire extinguisher handy though along with some alarms.(houses should have these at all times anyways)
Mar 07, 2015 | Televison & Video
The power lights flashes three times and the TV doesn't work
Three times flash to LG TVs denotes a fault with its main board. Contact any service technician. If you're sound in electronics, check this link. http://electronicshelponline.blogspot.com/ Blinking codes to many brand TVs are given in detail. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 23, 2013 | LG 47LG50 47 in. LCD HDTV
When I turn on power switch on back and then touch power button on front it beeps 3 times, shows an orange light and then immediately shuts down.IT wont let me take discs out. Is this a fatal fault in the...
There are three things that you can do. (1) Turn the console of for 30 minutes and try to restart it again. Sometimes the PS3 will overheat and give you the orange light error. (2) Turn you console off and you modem/router. After 2-3 minutes, power both back on and see if it works. This error is sometimes caused by interference with a wireless connection. (3) Turn your console off and carefully remove the hard drive and put it back in. It is unsure what causes this to work, but sometimes it does.
If none of the three work, you will have to have a major repair done on your console.
May 05, 2011 | Sony Playstation 3 (PS3) Console
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
How do you read the flashing check engine light codes on a 93 chrysler town & country?
Turn key on and off twice without starting engine. count flashes, their will be slight hesitation, make one digit after hesitation make second digit.(flashes 5 times hesitates flashes three times hesitates your code is 53) if it countiues to flash, its making second two digit code.
Jan 27, 2010 | 2005 Chrysler Town & Country
How to reset oil light after oil change on 2005 trailblazer
  1. Turn the key to the "ON" position
  2. Press the accelerator all the way to the floor 3 times within 5 seconds
  3. You should see the oil light flash, once it stops flashing, turn the key off
  4. Wait 10 seconds before starting the vehicle, the oil light should now be reset
  5. If this doesn't reset the light, repeat steps 1-4 paying careful attention to pressing accelerator all the way to the floor 3 times within 5 seconds
Best of luck.
Greg
Aug 10, 2009 | 2005 Chevrolet TrailBlazer
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Slow taking pic, flash flashes multiple times while lenses acts like it is trying to focus
The evolt cameras use the flash bursts as a "autofocus help". Try to find points with high contrast or edges to point one of the three autofocus points at (you see these points while looking through the viewfinder and they flash red as soon as the camera is focused).
So, flash bursts basically mean "too low light" some other situation which is hard for the camera to focus. In such situations, try to switch to MF mode (manual focus). Or you could buy an external flash (e.g. Olympus FL-36) which has a red light for autofocus assistance instead of flash bursts.
Dec 05, 2007 | Olympus EVOLT E-500 Digital Camera
My xbox no show no picture
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
LG 42LC2D 42 in. LCD HDTV Logo
75 people viewed this question
Computer Repairing
Computer Repairing
