Question about Altec Lansing inMotion Portable Speakers for Apple iPod and Most MP3 Players
IM600 does not switch on but green power charge button is displayed
The unit is plugged into a power source but will not switch on by either the power button or remote control. iPod does however charge.
  • Anonymous May 20, 2008
    The power button light flashes, but it won't turn on until I close the thing completely and push the button to re-open it--then it turns on, but it won't play songs all the way through. It plays about 3/4 of a song and starts it over. If I plug a cable into the aux jack and plug the other end into my ipod headphones jack, it works.
  • robmsn2002 Jul 05, 2008
    My im600 resets permanently each 5-6 seconds, anytime i switch it on with power cord or battery.
Did you have anyluck getting it apart i have the same problem with mine i think its the power button but i can get the plastic all the way off underneath it
Posted on Jul 19, 2009
I'm disassembling mine today, but am stuck getting the whole unit apart. I did take the two screws off in the back and that is where you'll find the lithium battery. It is attached with a standard cable that allows you to remove the battery and replace yourself with no tools required (aside from those two initial screws).
Will try to post my solutions later today if I get anywhere...FYI, if you get your unit wet, be sure to remove the battery as QUICKLY as possible, then let the unit dry out. Otherwise you'll be stuck with a dead unit like mine. You might be able to clean the green corrosion off the components inside that are causing the unit to short out (thanks to the battery being still connected while wet). That's what I'm trying to do as we speak.
Posted on Sep 07, 2008
Westinghouse ld-2480 powers up with red light however will not turn on to blue light
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 29, 2014 | Televison & Video
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
It's stuck and won't play the songs
  1. First make sure that your iPod’s hold button is of. (This is the little switch at the top left corner).
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
Aug 27, 2010 | Apple iPod nano
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    Froozen and wont do ANYTHING
      • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
      • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
      • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
      • While in disk mode, connect the iPod to iTunes and try to restore.
      • If the iPod is still not recognized by iTunes, the iPod should be serviced.
      • utting iPods with a Click Wheel into disk mode
        1. Before placing the iPod into disk mode, you should verify that it is charged.
        2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
        3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
        4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
        5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
        If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
        If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
    Jun 05, 2010 | Apple iPod nano
    When i got done chrging my ipod it froze
    Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
    Resolution If you experience any of the above issues, try the following steps:
    Dec 17, 2009 | Apple iPod Photo MP3 Player
    My ipod nano is stuck on language selection and is frozen can you help me?
    If your iPod is frozen or won't turn on, the steps to reset it vary by model.
      Hope i helped you.
    Thanks.
    Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
    Ipod connection
    As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
    Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
    Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
    As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
    Dec 29, 2007 | Pioneer DEH-P6800MP CD Player
    Regional code change for a samsung ht-db120n
    1) Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6) Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control. Your player is now region free. A word of caution is that you may have disc eject issues, in which case you will have to eject from the unit, or toggle the power switch on/off. This issue only arises if you have a particular chipset in your player (about a 20% chance).....good luck my friend.
    Aug 01, 2007 | Samsung HT-DB120 System
    Altec Lansing inMotion Portable Speakers for Apple iPod and Most MP3 Players Logo
    291 people viewed this question
    Top Altec Lansing Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Sharps s
    Level 1 Expert
    Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
