Need to replace a switch in control panel, how do I access it
    President:
  • 3,773 Answers
2 screws one on ea side of console (where the knobs are)
Pull the console forward , up and flip backwards
Then you will have access to all controls
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
Volume control on dvd plaYER
the volume switch ( tact switch ) which need a replacement. you will need to access the button panel to check the switch. you will need to unscrew to remove cover and panel.
Mar 01, 2014 | Sylvania Televison & Video
How to access control panel
What are you trying to replace the switch on??? A boiler ?? stove?? heater?? water heater??
Dec 26, 2011 | Ovens
Trying to take off the back and top control panel of my Kenmore Elite top load washing machine so I can replace the lid switch and timer, any help would be appreciated.
It is rare that a lid switch and timer both need replacing.
The 2 ends caps on the control panel will snap off.
Once they are removed,take out the 2 screws on the right and left front sides of the control panel that holds the panel to the top.
Fold the control panel to the rear of the machine.
Unplug the lid switch wire.
Remove the 2 S clips holding the rear panel to the cabinet.
Pull the cabinet forward to remove it.
The lid switch is then accessible inside the cabinet.
Reverse this procedure to re-assemble.
Jul 17, 2011 | Kenmore Washing Machines
The oven does not heat, the fan works but no heat. The amber panel light on the front doesn't come on either.
There is a faulty component inside the unit that is why it is not turning on. The power is working fine, because it is the power that operates the fan. Therefore the panel light that is not turning on is as a result of a bad component. In order to be sure what the faulty component is i will advice that you run a test on the oven, test the oven selector switch, to test the switch,
  1. There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial.
  2. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested.
  3. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced.
To install a new oven selector dial switch,
  1. Remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached.
  2. Transfer the wires one at a time from the old switch to the correct terminal of the new switch.
  3. Check your wiring diagram to make sure all wires are on the correct terminals.
  4. Now mount the new switch to the back of the control panel and replace the cover.
Also you need to test the thermostat of the oven to be sure the problem is not from there,
  1. Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable back splash. Lift the backsplash, rest it on the cook top and remove the screws from the back splash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  2. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  3. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
  4. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To replace the thermostat of the oven, please follow the steps below:
  1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
  2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
To install a new thermostat,
  1. Reverse the disassembly procedures,
  2. Transfer the wires individually from the old unit to the new.
Hope this helped. Thank you for using fixya.
Jan 21, 2011 | Explorer Appliances B196 ELECTRIC Kitchen...
Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
    1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
    2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
    3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
    4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
    5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
Dec 24, 2010 | Dryers
NEED TO REPLACE THERMAL SWITCH RBS305PDB6 WHERE IS IT LOCATED?
The thermal switch is located behind the control panel. In order to access remove the control panel. It should be located inside the aperture.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool RBD305PD Electric Double Oven
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
How to replace lid switch
you should either have screw at both sides on rear of control panel. if not you have tension clamps at right and left side at bottom of control panel in front. use putty knife. flip control panel back. undo lid switch harness. lift lid up and pull lid switch out. remove 5/16 ground screw first
Jun 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Repalcing an infinite switch on Kitchen Aid KERC607HBS4
If you are replacing the infinite switch, you need to remove the back panel of the console. This may include having to remove all, or part, of the entire back panel to gain full access. If you are replacing the thermostat on the heating element, or the element all together, you will need to lift the cook top up for access. This is acommpished by removing the screws along the front edge of the top panel. You will need to open the oven door to see the screws. Make sure you unplug the range prior to servicing any internal components. I hope this answers your question. If not, please let me know.
Jun 09, 2009 | KitchenAid KERC607HBS Electric Kitchen...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
